Hi
Have a pair of Hayes stokers that I want to change the hydraulic hose routing on.
Currently they terminate in the lever with an olive and compression nut, I would like to change this to a 90deg banjo fitting, however the fittings I have are a smaller diameter bolt.
Anyone done this? Or have suggestions how to achieve this.
It's for a DIY hydraulic to cable drop bar brake
Posted : 16/12/2012 10:46 am
If you switch to Goodridge hose, you can often get fittings that will fit most brakes in both banjo and inline types.
Posted : 16/12/2012 11:05 am
Cheers, I've got some hope/ Goodrich banjos but the hollow bolt is too small a diameter to fit the same bit as the compression nut. Think I need roughly a 8mm banjo fitting.
Posted : 16/12/2012 5:50 pm
pretty such you can get the goodridge stuff in 6mm and 8mm banjos
Posted : 16/12/2012 6:08 pm
