Brake Disk adaptor ...
[Closed] Brake Disk adaptor Advice... heads sore from scrathing... post to IS
I have an old set of XT brakes that are IS mount, a 203mm rotor and a shiny new pair of Lyriks with are Post mount...
I may well be being thick here but I can't locate a suitable adaptor. This is the closet that I have found, [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=13744 ]170mm adaptor on CRC[/url]
Any advice greatfully recieved.
Nick
Posted : 21/09/2009 10:43 am
Nick, I went through this with my hope set up. There is no easy or elegant fix with adaptors. Either sell you old xt and buy a new set or buy a new caliper to use with existing lever. Found these on crc which would work.
http://www.chainreactioncycles.com/Models.aspx?ModelID=37443
http://www.chainreactioncycles.com/Models.aspx?ModelID=13747
Not xt but it should work with your levers. You can always sell spare rotor and mount to get some cash back.
Personally I sold old set up and bought new set specific for forks.
Posted : 21/09/2009 11:13 am
What about [url= http://www.allterraincycles.co.uk/product/118209.html ] this[/url]
Posted : 21/09/2009 11:17 am
MM, I may be wrong but I think thats for the other way round. I found the same, there are plenty of adaptors if you have an IS fork and post caliper but not the other way round.
Posted : 21/09/2009 11:30 am
Yep that is the wrong way round.
Posted : 21/09/2009 11:33 am
Thanks for the advice... and yes Mulletus unforuntately thats the wrong way round.
It looks like I may have to upgrade to a new set of brakes then... I was considering that option but havent really got the gold reserves for it at the moment.
Acually, I have access to a workshop. Is there anywhere I could get the required offsets so I could machine up my own?
Nick
Posted : 21/09/2009 11:42 am
Giant used to do one
Was for a 164mm rotor (standard caliper went straight onto a 160mm IS fork normally so the caliper was the +4mm bit
So it should let you run a 160mm rotor, post mount fork (are lyriks 160mm direct fit? (or 203mm direct fit?) and standard caliper
Whether or not it will fit around a shimano caliper I don't know but Giant MPH-3 calipers are pretty big
I never bought one but when I was considering a post mount fork I asked my LBS (JeJames Rotherham) 2 years ago they had them in stock. Ring round some Giant dealers and see if they've got nay left (The MPH brake isn't made any more)
Hope (and others) do a +40mm adapter if needed
Posted : 21/09/2009 11:50 am
THanks for all the info James. Is this the giant adaptor you make reference to? [url= http://www.cyclesportsuk.co.uk/product_info.php?products_id=6000 ]Adaptor[/url]
If so it just looks like a post to post adaptor?
I believe the lyrics are 160 direct mounts.
Nick
Posted : 21/09/2009 12:06 pm
Actually... I think I've just found what I'm after
[url= http://www.tredz.co.uk/.A2Z-Post-Mount-160mm-to-International-Standard-203mm_17646.htm ]A2Z[/url]
Posted : 21/09/2009 12:09 pm
i think your choices are 180mm disc with hope adapter:
http://www.chainreactioncycles.com/Models.aspx?ModelID=13735
or as you've identified, the a2z adapter, only £11 at woollyhatshop:
http://www.woollyhatshop.com/view_product.php?id=2111
Posted : 21/09/2009 12:32 pm
Ordered the A2Z option... many thanks for all your help!
Posted : 22/09/2009 1:29 pm
