braided steel hose ...
[Closed] braided steel hose cutter
Can does anyone know where I can get a cheap hose cutter?
I don't really want to spend £40 on something I'm not going to use much!
Cheers, Chris
Posted : 11/02/2013 3:16 pm
Stanley knife with a nice new blade, a flat surface and a bit of elbow grease. Use a coctail stick afterwards to make the bore round again
Posted : 11/02/2013 3:17 pm
wrap where you'll cut tightly with masking tape - it helps prevent fraying.
I used to use a hacksaw with a new blade on car braided hoses.
Posted : 11/02/2013 3:38 pm
halfords <do I spit now?> cable cutter for 22 quid is great
i used it on braided hose for my M4s and it cut fine
plus if you buy it online, you get 20% off
and if you buy it with some GT85, the price actually drops by 50p
Posted : 11/02/2013 3:59 pm
Whatever you use to cut gear outers will cut braided hoses.
Or an angle grinder.
Posted : 11/02/2013 4:20 pm
Piedi Stanley knife on braided hose. Are you having a Giraffe. Would like to come and watch you try 😆
Posted : 11/02/2013 7:29 pm
Superstar Components do one Ive used..
Posted : 11/02/2013 7:43 pm
The best way (other than a proper hose saw) is to wrap it with masking tape then cut it with an angle grinder with the thinnest cutting disc you can find.
Even new hacksaw blades leave a ragged edge and cable cutters will crush the ptfe inner which isn't the end of the world but means you have to mess about squashing it back into shape!
Posted : 11/02/2013 8:26 pm
You can borrow mine if you like.
Posted : 11/02/2013 8:49 pm
