Bought tapered rigi...
[Closed] Bought tapered rigid fork by mistake.
[#4833256]
Advice please.
Bought an on one tapered carbon fork by mistake (tried to flog it on here but no takers) and had it lying in the cupboard for a few months. Only discovered that it was tapered when I went to fit it a coupla weeks ago (too late to return I presume?). Can I get a headset that lets me stick it into "regular" non-tapered frame? Does this affect handling etc?
Posted : 04/02/2013 4:02 pm
Tapered steerer won't fit in non tapered head tube. No adapters etc, it'llnever fit
Posted : 04/02/2013 4:12 pm
Depends on the frame- what have you got?
Posted : 04/02/2013 4:15 pm
dremel
Posted : 04/02/2013 5:34 pm
 lump
Posted : 04/02/2013 5:37 pm
Chap it in with big hammer, it'll be fine.
Posted : 04/02/2013 5:38 pm
 IA
If it's a 44mm integrated headtube you can use a hope external cup to make it fit IF the taper clears the inside of the headtube ok (probably will, but check).
Regular headtube? No chance.
Posted : 04/02/2013 5:41 pm
Have you spoken to On-One, must be worth a call to see if they would swap it for you?
Posted : 04/02/2013 6:02 pm
Emailed on one and they will exchange, so fair play to them. Turns out that I had ordered the right ones and this was send out by mistake.
Posted : 04/02/2013 6:07 pm
Which fork was it - Lurcher, what colour ?....
cheers
Posted : 13/02/2013 6:27 pm
