Bottomless Tokens -...
[Closed] Bottomless Tokens - Whyte T130RS
Is there a rule of thumb for adding tokens and reducing air pressure?
I'm going to add a third one and my thinking was dropping 10-15 psi
Anyone else had success with such a set up?
Posted : 26/08/2016 11:48 am
Worked for me on my 2016 RS – going to 3 tokens meant I could drop the pressure about 10-15 psi (can't remember exactly, sorry), run more sag (30%) but with decent support and ramp-up.
Fork pressure now ~82 psi (I weigh about 100kg), no compression damping and rebound 8 clicks from slow (still playing with rebound settings but you might need to adjust with the change in spring rate).
Also tried 4 tokens but that was a step too far for me.
Posted : 26/08/2016 12:51 pm
