Has anyone tried cutting down the size of Bottomless Tokens to fine tune their forks? I have Pikes at 130mm and find 2 Tokens too linear and 3 too progressive so thinking about cutting a spare one in half to run 2.5 Tokens. I can't think of anything that could go wrong providing Token doesn't fall apart inside the forks.
So, has anyone else done this? Im guessing on longer travel set-ups the difference between 1 and 2 Tokens is less than on shorter travel set-ups.
My thoughts exactly.
Same issue as you describe and I weigh 10 stone 8.
I'll be watching this.
I have done this
Hacksaw in half, clean with a sheet of sandpaper, run a lighter over the area cut to burn any burrs. Hole for Allen key runs all the way through so it tightens up ok.
Only thing that can go wrong is that if it is not cleaned up right any loose debris could fall of and go in to the Airshaft seals.
I'm getting some of these, is it right that you need more for a shorter travel fork?
I only weigh just over 11 stone, with a 130mm fork.
Yes.
Mine are 130 and had 2 pre installed. 160mm have none pre installed. If you google pike bottomless tokens theres a few charts that show how many are pre installed and the max you can install.
Mine are rev's so it's the 32mm I've got coming.
Not sure if it will be the same.
