Bottomless tokens a...
Bottomless tokens after shock upgrade
I have a Yari that’s just been upgraded to Debonair, +20mm travel and Charger RC2.
I previously had 2 tokens in it.
Today I’m out playing with bike setup, it’s also now on a new bike, so lots of changes.
Is the general wisdom to start with no tokens now I’ve got the better internals? I’ve taken one out and I think it feels better and will try taking the other out too and / or drop the pressure by 5psi but just wondered if there was a role of thumb for base settings?
Posted : 17/11/2022 12:38 pm
OK so I’ve just found the HSC was all the way to + which might have something to do with my disappointment with my fork.
I’ll try again with it open!
(I’m sitting on the bike in the rain typing this).
Posted : 17/11/2022 12:42 pm
Haha, yes start with the HSC all the way off and add some as you need it.
There are RockShox docs which show the recommended tokens for a given length of travel, I find them to be accurate.
Posted : 17/11/2022 12:57 pm
Yeah it feels much better already and I’m no longer grumpy! 🤣
Posted : 17/11/2022 1:00 pm
More travel, definitely remove a token or two. Can’t see the damper upgrade making a difference as the token only affects the air spring.
I generally remove them as a matter of course and add back in if harsh bottoming is an issue, which given my (negative) level of radness it usually isn’t.
Posted : 17/11/2022 1:02 pm
Cheers.
It feels good now with no tokens and fully open.
I’ll have a play with the compression a bit now 👍
I was struggling to find a chart relating to it as it’s not a standard fork anymore 🤷🏻‍♂️
Posted : 17/11/2022 1:39 pm
I’d use the Lyrik guide rather than Yari as you have a newer air shaft and charger damper.
I think sram tech docs on a 150mm fork is 1 or 2 tokens - but that’s just ballpark.
I’d probably start with no tokens and all damping fully open. Get the air spring setup ballpark - maybe aiming for 25% sag ish.
Then setup rebound so it’s as fast as it can be without being a pogo stick.
Then ride and see how it goes. If it’s banging hard through all the travel and bottoming out I’d add a token and try again.
Once that’s dialled in if the bike is bobbing a bit then add lsc.
If you find you’re too deep in the fork too often for your liking, but not bottoming out as such, then add some hsc.
Posted : 17/11/2022 3:28 pm
@joebristol cheers.
I’ll be back out tomorrow but was pretty happy with it in the end yesterday.
Posted : 18/11/2022 5:59 pm
