Bottom bracket thre...
[Closed] Bottom bracket thread stripped
 benz
Old BB seemed to go in nicely then did not want to come out nicely.
Result some damage to thread on chainset side.
I'm going to try me LBS initally to see if they can chase the thread through, but if this is not successful, then can anyone recommend an alternative?
BETD are my first consideration.
Posted : 18/04/2009 8:48 am
Any alternative is likely to be expensive if chasing the threads wont work.
Engineering solutions I can think of are - build it up with weld, machine to right size and recut thread or cut to a larger thread if there is enough material make an inset to thread in that can have a bb thread cut into it.
I have had both done on motorcycle parts in the past - smaller threads tho
Posted : 18/04/2009 10:19 am
your LBS should be able to re-thread it at a cost of around £10
i went through this similar process when i changed over a BB recently.
Posted : 18/04/2009 10:23 am
Something like [url= http://www.sjscycles.co.uk/product.asp?pf_id=16505&src=froogle ]this maybe[/url]?
Google for threadless bottom brackets for more or there is a company who can bond in a new threaded sleeve but cannot remember who they are, and have no experience of either solution. Someone on here probably does though.
Posted : 18/04/2009 10:27 am
They can only rethread it if there's material left to rethread if you've really stripped it you may be screwed!
Posted : 18/04/2009 11:01 am
I'm in a similar position on my s/s - I'll be off to the LBS to see what they can do. Otherwise, as it's a steel frame, I'll be off to the framewelder - so it depends upon what your frame is made of.
Posted : 18/04/2009 11:32 am
What about using a cup with a longer thread - RaceFace DH ones are substantively longer and will go into the thread thats not ****ed
Posted : 18/04/2009 11:35 am
I once bought a cheapo steel mtb frame that turned out to have an italian bottom bracket thread.
The bike shop reamed out the old thread, fitted a sleeve & then re-tapped the thread. I didnt pay as the shop sorted it out, but I seem to remember it was about £25.
Any decent frame builder should be able to do this for you.
Posted : 18/04/2009 11:41 am
if it's properly knackered then argos racing cycles can ream and sleeve the shell.
Posted : 18/04/2009 6:59 pm
charliethebikemonger used to sell a 'threadless' square taper bb which screws into itself not the shell. Probably only a goer if you already have the right cranks, might then work out cheaper than a repair.
Posted : 18/04/2009 7:08 pm
I keep reading about stripped/seized threads, particularly BBs - are all these people hamfisted numpties? I have minimal mechanical aptitude but I never had a problem with BBs...
Posted : 18/04/2009 7:16 pm
 igm
If it's a steel frame, as one of the post above is, you'd do well to strip the thread with an alloy bottom bracket - so you're probably OK with a chase. If the frame is Al or the bottom bracket is steel then there may be more problems.
Posted : 18/04/2009 7:24 pm
Don't worry, this happened to me with my Cove Stiffee (for the record i didn't cross thread it they 'pulled' out, i guess due to prolonged hard riding) Anyway sent it off to BETD who drilled out the damaged side, fitted a sleave then re cut the threads, £45 incl return postage.
Oh and BTW don't be tempted to buy a threadless BB, they're bobbins.
Posted : 18/04/2009 9:47 pm
If you dont care about the frame araldite the bracket in, a member of our sales team and our former buyer have both been rolling on araldite for a couple years. Otherwise we sell the pristine brackets as someone has already suggested. A friend at uni had an Argos sleeve in his MsIsle, it was a top fix and cost £60 or £80 I think.
Posted : 18/04/2009 10:57 pm
 benz
swisstony - exactly the route I'm going to go down so appreciate the positive feedback. Spoke with them yesterday and they advise not an issue to fix at all.
Surprisingly, none of my LBS's had the tools to chase the threads in the bb through...which I found a bit strange. It's an alloy frame
Threads picked up when taking our the chainset side - and I applied much force to get the bb out....my fault!
Posted : 19/04/2009 11:55 am
