Bottom bracket seiz...
[Closed] Bottom bracket seizure...... again!!!
Hi guys,
My BB has seized bearings for ther second time in 4 months, first time was just after finishing a very wet West Highland Way in May, and now again after a bit of a damp one up the Pentlands.
Its a [b]Superstar Angletech BB[/b] (SS = Marmite!) and I have a Deore HT2 Crankset.
I've sent the BB back to Superstar for a check, they changed the bearings in May/June stating that they'd been fitted the wrong way at the factory, hence the seizure. I'm pretty anal when fitting things like this, spacers in the right config. not overtightened, everything spotlessly clean etc etc, I have noticed that the plastic spacers are very cheese-like....
Is there anything I might be doing wrong? I haven't had the BB tube faced, but measuring it all round with a vernier caliper it seems to be bang on, and the faces are clean and flat. The Shimano one that I got with the crankset lasted well over a year. 🙄
Posted : 15/10/2011 11:38 pm
 GW
stick with Deore BBs
Posted : 15/10/2011 11:55 pm
any rust in the bottom of the frame, also check the drain hole is free and open.
Simple checks I know.
Posted : 15/10/2011 11:58 pm
Buy red hope one kinda fit and forget part lol
Posted : 16/10/2011 9:33 am
Don't buy a SS BB would be the best advice I could give!
Posted : 16/10/2011 10:29 am
When I got mine, I opened up the bearings to add more grease and found they were quite dry to start with.
With that, the bearings lasted for about a year regularly riding in the Peak and being somewhat lacking in the cleaning department. When they went, I changed to them for some Stainless bearings with a rubber seal from AK Bearings (Part: 61805-2RS ) and they're still going strong, (only 6 months old though)
Posted : 16/10/2011 10:40 am
I had problems with my bb Superstar Angletech BB lasted 1 month found water was going down seat tube , taped it over got Shimano £20 bb now runs smooth but superstar should have lasted longer
Posted : 16/10/2011 8:58 pm
Take note of his last words,folks.
So many people are just far too handy with a hose.If you hose the bike,dont hose past the seatclamp.Who freekin cares if the saddle is filthy underneath!
Tape over the split at the top of the seat tube and clean/grease the post often.
Up front, dont go spraying water any higher than half way up the headtube. Same as the front.. if the shifters are filthy,water spraying into them aint going to help it. (even xtr arent sealed so keep the hose well away)
The back of an a-head stem and the split wedge on headsets arent the best design for keeping water out of the headset/headtube so dont bother hosing it down. If you do,water will work its way into the headtube,run down the breather holes and eventually fill up the bottom bracket.
If you fill the bottom bracket with enough water then the sleeve will be submerged when stationary.. Not to mention all the soakings the entire sleeve will see under use. You can clart the bearing cups with extra grease from the inside (lots can be pushed in by finger next to the inner rubber seal and the alloy cup) before fitting the unit to help keep the water away but no matter what quality of bb unit you buy into.. a hose blasting around the top part of a headset and seatpost split wont do you any favours.
Also measure the width of the shell BEFORE fitting the unit with digi verniers and take a measurement of the bb unit with the correct number of spacers. If you put 2+2 together you can work out how much the o-rings are actually doing their job once the unit is fitted.Sometimes too many spacers or too little could be compressing the sleeve (allowing it to deform once tightened - meaning that its going to let water in past the o-rings) or one end of the sleeve wont be fitted into the cup correctly at all.. meaning that the o-ring is just a waste of time.
I have soaked some of my bikes under normal use (not with a hose) and the shimano bb units fitted years ago with extra grease from new still works like new (one nearly 5 year old now)
Once hosed down to destruction, most bb units seem to fail when they have been sitting around for a week+ at a time.This gives them time to rust up.
Now if i dont ride my bike at all ;O)...then surely all my bb units must be rusted solid.
<awaits flaming from folk that know me :O)
Posted : 16/10/2011 9:57 pm
or take the sleeve off and drill a BB drain hole
Posted : 16/10/2011 10:05 pm
