Bottom bracket comp...
[Closed] Bottom bracket compatibility
Folks.
I'm looking for a new (second hand) chainset for my Cube Team Ltd MTB. It's Shimano equipped with a Hollowtech bottom bracket.
Do I have to specifically buy a chainset with a Hollowtech fitting or can I contemplate something different i.e. Mega Exo Pro or GXP ?
Thanks.
Posted : 16/10/2015 2:19 pm
Shimano HT2 chainsets have a 24mm axle, if you intend to keep the same BB then you will need something shimano compatible with a 24mm axle. Is your BB threaded or press fit.? If you go for a different make of chainset you will most probably have to change the BB. Off the top of my head I think GPX was 24mm.
Posted : 16/10/2015 2:27 pm
GXP isn't directly compatible with an HT2 BB, despite having the same axle diameter. It'll need an adapter. I'm not sure if the adapters are generic. I'm running got a hope HT2 BB with the Hope GXP adapters for my SRAM GXP chainset.
Posted : 16/10/2015 3:35 pm
