Bottom bracket choi...
[Closed] Bottom bracket choice on Chinese Carbon frame
[#9433405]
I've been offered a frame with either 112-49-BB30, 112-52-BSA, 112-56-BSA bottom brackets.
All being equal, I prefer threaded, but is everything equal.
On this kind of bike, does it affect q-factor, or anything else?
Posted : 13/07/2017 8:54 am
Bear in mind narrow Q-factor is only of benefit if you ride with your feet 'straight' - not unknown for those with bigger feet / ride toe-out for heels to clip the chainstays. Those dimensions would seem to indicate that you'll need to fit some form of adaptor anyway - i.e. a BB30 bearing/6806 is 42mm diameter and PF30 is 46mm. I would stick to BSA as it probably gives you more options - What crank are you wanting to use?
Posted : 13/07/2017 9:20 am
I currently have a BB30 crank off a Boardman CX Team, but was hoping to move to SRAM Force 1, or similar 1x.
Posted : 13/07/2017 9:23 am
BSA would be my choice.
My workswell supplied BB bearings lasted 3,200 miles in all conditions though so I wouldn't rule out BB30 (although mine is BBright).
Also just bought a new BB30 frame and got these: https://www.ribblecycles.co.uk/ribble-road-press-fit-bb-cups/#pid=18324
Standard easy to reach MR2437 bearings in a proper alloy case 🙂
Posted : 13/07/2017 12:21 pm
Looks like Sram Force 1 uses 24mm spindle, so I guess I'm not limiting my choices by sticking with BSA.
Posted : 13/07/2017 1:02 pm
I'm assuming that the 112 BB reference means a 112mm-wide BB shell - what width is the BB shell on your Boardman? You can get longer crank spindles, provided you can detach it from the spider.
Posted : 13/07/2017 1:49 pm
