Hi,
I've recently bought a used Calibre Bossnut on Gumtree (uh oh) and whilst it looks like it's been well care for and upgraded there's significant play around the rear linkages/suspension and many of the bolts are rounded off probably in an attempt to sort the issue.
My question is, does anyone know where I can get a full bearing/bush set as well as the bolts to try and sort the problem properly? Are these common sizes or unique to these bikes? It's a Rockshox Monarch R rear shock. This is my first full-suss bike so unsure which way to proceed.
Thanks,
Iain
1/2"X1/2" bushings and 8mmx22mm shock mount hardware I think.
If it helps I was strolling around Go Outdoors today, they had a bit of a Bike Workshop going on in the back of the shop I'm sure they would help you if you have one close to you. They've been pretty good to Calibre owners etc.
Seeing as Go Outdoors own Calibre, I should hope so!
