Boring brake questi...
[Closed] Boring brake question
Going to try a 203 mm rotor on the front from a 180 mm which has the caliper mounted directly onto the fork. Can't see an adapter for a 180 direct mount to 203 online, will a 160-180 do the same job if I maybe add a washer or two?
Posted : 06/11/2016 11:32 am
Yes!
Posted : 06/11/2016 11:54 am
Don't bodge your brakes with washers...
Shimano SM-MA-F203-P/PM or SM-MA90-F203P/P
si.shimano.com/php/download.php?file=pdf/um/SI-0146A-000-00-ENG.pdf
Posted : 06/11/2016 12:00 pm
Hope's H type mount should do the job for most calipers without the need for washers, but a washer on a 160-180/+20mm will work fine too, certainly better than Tillydog's suggestion which spaces it out 10mm too far.
Posted : 06/11/2016 1:29 pm
How does it do that? The tech doc for that adaptor says it's for taking a 180mm mount to a 203mm one...
Posted : 06/11/2016 1:35 pm
There's always one ! ๐Ÿ˜€
Those are +23mm adapters, for 180-->203mm
+20mm adapters will almost certainly cause clearance issues between the caliper and the edge of the 203mm disc.
[ETA: +20, etc. refers to disc diameter, not caliper spacing]
Posted : 06/11/2016 4:18 pm
Fox do one that is for a 180mm post mount to 203mm post mount.
Posted : 06/11/2016 5:53 pm
My mistake, apologies all round ๐Ÿ˜ณ
Posted : 06/11/2016 6:16 pm
