Borderline mental b...
[Closed] Borderline mental brake down over brake hose fittings!
Why are brakes so effing annoying!
Soooo.....
I have a Guide RSC with a hose which is to short so I need a longer one.
I have worked out the hose bit (Superstar) and the Olive watsits but do I need new fittings like banjos and weird nuts 'n bolts for replacing a whole hose.
Pls help
Posted : 15/08/2017 6:56 pm
Can't you just buy a sram hose? They're only about £25 and it will all work out of the box.
I could be wrong but I'm pretty sure you can't get the actual sram hose fitting separately for guides.
Jagwire version is £12.50, don't know how much the hose is but I bet you're around £20 all in. You need the hfa202 kit.
https://www.acycles.co.uk/jagwire-hyflow-quick-fit-adaptor-kit-avid-elixir-5-7-9-x0-r-cr-cr-mag-4312.html?gclid=EAIaIQobChMI-rSszOzZ1QIVjxDTCh17WwcFEAQYASABEgLzevD_BwE
I THINK you need kit 4 from superstar which is showing out of stock.
Posted : 15/08/2017 7:10 pm
Thanks!
Posted : 15/08/2017 7:45 pm
