Boost wheel adapter...
[Closed] Boost wheel adapters - much of a muchness?
Looking to get a new fork, seen a good price on a boost version, but would need to adapt my wheel (Pro 2 hub)
The below seems to do the trick
https://www.xcracer.com/shop/viewproduct.php?productid=447
Any better options for the price?
Posted : 25/02/2020 8:28 am
The hope one for a front wheel works well. End caps that fit and all goes together properly, costs less than say a wolf tooth one, (though now than the cheap washer types).
I wouldn't look anywhere else in your case.
Posted : 25/02/2020 9:13 am
Yeah, I use the Hope one, does the job nicely, but does require a wheel dish.
The one above requires no dishing, but those little spacers will fall off every time you remove a wheel. How annoying that will be depends on how often you remove a wheel.
Posted : 25/02/2020 10:05 am
If there are adaptors for you hubs then use those rather than generic ones.
Generic ones work fine but the spacers can be fiddly
Posted : 25/02/2020 10:09 am
Not as cheap but the MRP Better Boost kit is a well made fit and forget set up. You get proper end caps for each side so no need to redish the wheel.
Posted : 25/02/2020 10:34 am
MRP quote max rotor size of 185mm (as do others with the disc spacers) but the Hope one doesn't require a disc spacer (although does require wheel re-dishing) and so can use a 200/203mm rotor.
Posted : 25/02/2020 10:46 am
Get the Hope one and re-dish 5mm, the spokes have better and more equal angle and tension thus stronger. Available in torque cap as well. I've done it, so can recommend.
Less than a tenner if you only need the driveside one, perfect, the two loose spacer options are a PITA and could void warranty.
Hope make this stuff for their hubs, other companies don't even bother, gotta respect that.
Posted : 25/02/2020 8:18 pm
Will I need new spokes to re-dish the wheel?
Posted : 25/02/2020 9:50 pm
Not likely.
Those redishes are generally really small, like a quarter or half a turn of the nipples.
Have a Boostinator on my rear wheel, it was a quarter turn tightening on one side and a quarter turn loosening on the other
Posted : 25/02/2020 11:03 pm
I got a set of mt zoom ones off eBay for a tenner I think. Only problem is they are red and don't match my bike!!
Ha, just clicked the link in the op, those are the ones I got.
Posted : 25/02/2020 11:10 pm
About half a milli spoke difference on a spoke calculator, re-dish should be fine.
But more than a 1/4 turn in my experience.
Posted : 26/02/2020 6:12 pm
