Boost forks with a ...
[Closed] Boost forks with a standard 100mm hub? Can this work well?
I want to change my forks and a pair have come available at a good price but they are Boost (110mm). A quick search has pulled up a couple of eBay kits, but I want to know whether it's a bad idea or not. I'm happy with my wheelset and don't want to change it. Thanks.
Posted : 04/11/2016 5:03 pm
 br
Can you get a Boost conversion for the hubs?
Like this, although it's only one sided so will need the wheel re-spoke-ing.
https://www.bike-components.de/en/Hope/Conversion-Kit-for-Pro-2-Pro-2-EVO-Pro-4-Hubs-p14348/
Posted : 04/11/2016 5:33 pm
The wheels are Mavic Crossmax SLRs 29"
Posted : 04/11/2016 5:52 pm
Don't you have to redish wheels for boost?
Posted : 04/11/2016 6:42 pm
Won't the brake disk be in the wrong place?
Posted : 04/11/2016 6:48 pm
I thought the same.
Posted : 04/11/2016 7:01 pm
You can do the conversion in two ways:
- add a 10 mm spacer on the non-disc side, re-dish the wheel (this is what the Lindarets Boostinator does) - not sure if the Mavic spokes will allow you to do this
- add 5 mm spacers on each side and a 5mm spacer under the brake disc, no redishing required
Posted : 04/11/2016 7:02 pm
 km79
Nah, they can be any colour.
Posted : 04/11/2016 7:05 pm
I got a kit from eBay and it works great. As above, two 5mm spacers for the hub and one for the disc with slightly longer bolts.
