Bodge tech question...
[Closed] Bodge tech question 9 speed / 10 speed
Here is the set up I have a question on :
10 speed shifters, chainset, cassette and chain but with 9 speed front and real derailieurs. On the basis the derailiuer movement will be governed by the 10 speed shifters , this should work , or not ? Maybe some different jockey wheels ?
Any thoughts gratefully accepted !
Posted : 26/07/2011 3:46 pm
9 speed MTB Shimano rear mechs do not work with 10 speed MTB Shimano shifters.
Posted : 26/07/2011 3:48 pm
apology for slight threadjack, but anyone know if 10 speed c/set will run with 9 speed mech/chain ?
Posted : 26/07/2011 4:12 pm
Yep, chain/rings are cross compatible no problem.
As per Mister P, neither SRAM nor Shimano MTB components are 9/10 compatible. Shimano road 10 speed shifters can be used with a 9 speed rear mech though.
Posted : 26/07/2011 4:16 pm
Thanks 😀
Posted : 26/07/2011 5:43 pm
you can use the flat bar road shifters with a 9 speed rear mech if you want to keep rapid rise.
I managed to get a set for £25 on ebay but the price is very variable
Posted : 26/07/2011 5:48 pm
Quite like that name for a light engineering firm: BodgeTech Solutions Ltd.
Posted : 26/07/2011 5:55 pm
What exactly is not compatible though ?
scu98rkr - can you show me the shifters you mean ? Sounds an interesting option, as I like Rapid Rise.
Is it these ones ?
http://www.chainreactioncycles.com/Models.aspx?ModelID=35084
Michael
Posted : 27/07/2011 7:27 am
One click at shifter will not equal one sprocket on cassette. How incompatible do you want it?!
Those are the shifters yes.
Posted : 27/07/2011 8:53 am
[i]What exactly is not compatible though ?[/i]
The rear mech is not compatible with the shifters. The front mech will work although may not be 100% perfect.
Posted : 27/07/2011 9:21 am
You could get the 10 speed road version of the shifters...
Posted : 27/07/2011 9:22 am
[u]So it must be to do with lever ratio's at the rear mech then[/u] ?
As the cable pull is determined by the shifter, so if the ratio's were the same, there would not be any reason why you couldn't run a 9 speed rear mech with a 10 speed shifter as the overall travel is the same ie still the same width cassette/lateral distance between the biggest and smallest sprocket is still the same. ????
Posted : 27/07/2011 1:08 pm
You have pretty much answered your own question there. 9 and 10 use differing cable pull ratios.
Posted : 27/07/2011 1:39 pm
