boardman hybrid pro...
[Closed] boardman hybrid pro - zero wheels a warning
 dab
as above,
if you have the zero twin spoked disk wheels check the rim for corrosion, esp under the stickers, found a pea sized hole in the rear rim tonight whilst replacing a spoke ....almost all the eyelets showing corrosion some cracks under the anodising
scary !!!
Posted : 22/06/2010 8:05 pm
