Blind bearing remov...
[Closed] Blind bearing removal tip
I needed to change all the bearings in my Cotic Hemlock.
The main frame bearings were blind due to having a sleeve between them that had got stuck in place.
I looked at the price of blind bearing removal kits (about £120) before realising that concrete stud fixings were pretty much the same.
So used a M10 concrete anchor, drifted down the pin to splay out the legs and put a bolt in to keep them in place, and then drifted the bearings out easily from the other side.
Now hopefully I can find a bearing stockist open on a Saturday morning!
Posted : 20/02/2010 10:17 am
Also works well when the bearing falls apart just leaving the outer shell stuck in the hole...
Posted : 20/02/2010 10:23 am
good work that man!
Posted : 20/02/2010 10:39 am
4 bearing stockists around here and all Mon-Fri only 🙁
I should have looked at it one evening instead of waiting until today!
Posted : 20/02/2010 11:52 am
I like that idea a lot, I was also impressed when I saw a repair stand on the pavement in Chengdu having a bit of trouble getting a bearing out of a person pulled rubbish cart, after a couple minutes difficulty he reached for the stick welder and blobbed a couple quick sparks between the drift and bearing and promptly hit it out, all while the public were wandering by.
Posted : 21/02/2010 5:11 am
