Bleeding new style ...
[Closed] Bleeding new style Shimano brakes?
So what kit does everyone use and do you guys have any tips. Going to attempt to bleed my zee's this weekend.
Posted : 15/01/2013 2:32 pm
you need the special bucket, and a bit of hose.
Syringes make it cleaner, but not essential.
Dave
Posted : 15/01/2013 2:34 pm
 edd
Buy a funnel...
[url] http://www.chainreactioncycles.com/Models.aspx?ModelID=34710 [/url]
...and some oil.
[url] http://www.chainreactioncycles.com/Models.aspx?ModelID=663 [/url]
Follow the instructions linked below paying particular attention to steps 8 and 9.
[url] http://techdocs.shimano.com/media/techdocs/content/cycle/SI/Deore-XT/SI_0116A/SI-0116A-001-00-Eng_v1_m56577569830746864.pdf [/url]
Posted : 15/01/2013 2:45 pm
i bought the little shimano funnel and a shimano squeezy bottle and hose. very easy.
tbh this kit looks better though and negates the need for funnel buying, or bottle squeezing:
http://www.ebay.co.uk/itm/Epic-Shimano-Brake-Bleed-Kit-2012-on-Funnel-Deore-Saint-XT-SLX-XTR-/170971712417?pt=UK_Spots_Leisure_Cycling_Tools_RepairKits&hash=item27ceb54ba1
you could get these bits cheaper separately, but can you be assed for £11.70?
Posted : 15/01/2013 4:50 pm
The 'Epic' kit makes it a doddle & they have 'how to' vids on their website too - [url= http://www.epicbleedsolutions.com/resources/videos/ ]HERE[/url]
Posted : 15/01/2013 5:01 pm
I tried the Epic kit and it didn't work that well with my M785's. I found the Shimano funnel thing worked pretty well. The newer Shimano brakes aren't as easy to bleed as the original ones which were so easy its untrue.
Posted : 15/01/2013 5:13 pm
I use the epic kit - top notch, no issues here.
Posted : 15/01/2013 6:25 pm
Funnel on top, syringe at the bottom and push fluid upwards. Easy peasy!
Posted : 15/01/2013 7:12 pm
Thanks for the referral guys.
Our kit does work well with the new Shimano brakes and we've sold a good few hundred up to yet with no issues.
Our videos section leaves a lot to be desired at the moment but we will be updating it soon.
There is a guide to bleeding the new Shimano 2012 brakes on our site though, check it out here:
http://www.epicbleedsolutions.com/blog/how-to-bleed-new-shimano-brakes/
Posted : 16/01/2013 11:01 pm
I bought the Epic kit.
Piece of cake to use!
Posted : 17/01/2013 12:00 am
I'm using the funnel system which works well. They recommend to use a bag on the end of the hose once you've pushed fluid up using a syringe. However, I kept the syringe on last night and used it to help 'suck' the fluid back down like with the avid system. Worked a treat and I got loads more air out using this method. Much cleaner too. Two really good bleeds later I'll use this method again
Posted : 17/01/2013 7:23 am
*marks thread for later*
Posted : 17/01/2013 7:42 am
Rickos - Member
same 😆
Posted : 17/01/2013 8:54 am
Buy a funnel...
...and some oil.
Do this, very easy and it works.
If you want better value then buy Motul LHM Plus Fluid from ebay instead of the Shimano rebranded stuff (it's the same), get a 50ml syringe from ebay/chemist and some plastic air stone tube from a pet shop.
Posted : 17/01/2013 9:14 am
Saaayy whhhaaaaatttt?
Posted : 17/01/2013 9:49 am
It's the plastic tubing you can buy in a pet shop for fish tank filters/air stones. I have a spare metre if anybody wants a short length?
Posted : 17/01/2013 9:54 am
