Bladder Problems
[Closed] Bladder Problems
I need a new bladder for my Camelbak.
Their own bladders have clearly improved over the years, but are they the best option, or are there some aftermarket bladders that I should look at (cheaper, stronger, easier to wash etc.)
Posted : 04/08/2009 12:00 pm
I find the Deuter ones much easier to empty and clean as they open across the full width of the bladder. The supplied valve is a bit marmite, but you can always fit the old Camelbak valve.
Posted : 04/08/2009 12:02 pm
the NEW new dakine one the sliding top bag version
will fit in a camel back
here is a photo of the same bag but used for another purpose
Posted : 04/08/2009 12:08 pm
here "the hydropak"
Posted : 04/08/2009 12:09 pm
I'd recommend not buying a platypus - I've been on a couple of trips now where people have had platypus bladders either explode when fallen on, or just start leaking, whereas my 8 year old camelbak one is still okay.
Camelbak used to do lifetime guarantee for the bladders didn't they? If yours is broken it might be worth checking that out.
Joe
Posted : 04/08/2009 12:10 pm
Fozzybear - you have answered a question I have been meaning to post. I struggle to open my Camelback bladder (small, weak girlie hands) and a friend had told me about one with a sliding top. Can you tell me if you can remove the valve also to brush inside the tube?
Posted : 04/08/2009 12:13 pm
 cxi
Might be worth looking at Source Hydration:
http://www.outdoorsmagic.com/news/article/mps/uan/6222
Posted : 04/08/2009 12:15 pm
Washing bladders... na that weird black stuff adds to the taste, and probably keeps any germs at bay ๐Ÿ™‚
Posted : 04/08/2009 12:49 pm
Have source fixed the dreadful mouthpiece?
Posted : 04/08/2009 12:52 pm
domino - yes you can just pull it off.. like a normal camelback, i find though as i clean the bag more as it's easier, plus less mess as the tube locks off at the bladder when you remove it, only fluid is stored in the tube, i normally blow air back into the bladder then pull the tube off..
so far it's the BEST bladder i have found. camelback ones are a bitch to clean ๐Ÿ™
Posted : 04/08/2009 1:01 pm
You clean your Camelbak?
(checks 7 year old bladder)
Nope, spotless.
Posted : 04/08/2009 1:12 pm
Rinse out your bladders after a ride and keep it in the freezer.
Never had gunk.
Posted : 04/08/2009 1:15 pm
I have a deuter bladder which is far better than the camelback bladder it replaced. Clip slides off and on without and difficulty at all, easy to clean/refill. Although the bite valve tends to slip after taking a drink and then leaks unless I push it back afterwards. Camelback bite valve leaked much worse though.
Posted : 04/08/2009 3:09 pm
