Blackspire stinger ...
[Closed] Blackspire stinger fouling chainring bolts ๐Ÿ™
isg05 mount
countersunk blackspire mounting bolts
73mm shell
1 drive side spacer
slx triple crankset with bash
chainring bolts foul the stinger mounting bolts - have i done something wrong or is this a dodgy combo?
Posted : 25/04/2012 6:51 pm
Did you use the washers?
Manual [url= http://www.blackspire.com/site_assets/www.blackspire.com/images/dynamic/Stinger_Setup_guide.pdf ]HERE[/url]
Posted : 25/04/2012 6:53 pm
no as this would push the stinger further into the chainring
Posted : 25/04/2012 6:54 pm
Are you talking about the granny ring bolts?
I had a similar setup that did that.
I just fitted lower profile bolts.
Posted : 25/04/2012 6:55 pm
yes granny ring bolts - low profile bolts - from where?
Posted : 25/04/2012 6:56 pm
The bottom draw of my toolbox. ๐Ÿ˜†
Just file yours down a bit.
Posted : 25/04/2012 6:57 pm
Just rode mine for a few miles til they wore down.
Posted : 25/04/2012 6:58 pm
i would file/ride but its pissing it down ๐Ÿ™‚
Posted : 25/04/2012 7:00 pm
I had the same problem with my Covert. Probably about 5mm out.
I thought the ISCG mounts were off but Transition reckon they're correct - flush with the edge of the BB on a 73mm shell.
Went for a Bionicon c.guide v2 in the end. Works really well.
Posted : 25/04/2012 7:14 pm
mines about 1mm - file time!
Posted : 25/04/2012 7:20 pm
Just use a 1mm B/B to shift everything across a bit, saves dicking about filing stuff.
Posted : 25/04/2012 7:32 pm
I have a Blackspire ISCG mount on my 2011 Covert with an SLX triple chainset converted to a double - no problems with mine.
Posted : 26/04/2012 12:01 pm
finally sorted with 4 flat chainring bolts!!
Posted : 06/05/2012 9:04 pm
I had to file mine too on my SC Butcher too
Posted : 06/05/2012 9:14 pm
