Bird Aether 9A with...
[Closed] Bird Aether 9A with 130mm fork.... yes or no?
I'm still trying to make my mind up on a new frame and despite longing for a steel hardtail I keep coming back to the Aether.
BUT
I can't afford a new fork if I go FS so would be transferring a 130mm Rockshox 35 over. The frame is optimised for 140mm and all geometry is listed with a 140mm fork, including BB height. Would a 130mm fork upset the balance and handling too much?
Posted : 10/08/2021 6:57 pm
Ben sometimes pops up on here but get on the bird Facebook group if you have it and Dan will usually give you a reply, otherwise send them them an email and they’ll tell you. Bird customer service is some of the best.
Posted : 10/08/2021 7:37 pm
Can you not get a 140 airspring for about £40?
Posted : 10/08/2021 7:43 pm
The Bird Lads told me 130mm was fine (when I was considering a 9C) - so should be fine on the 9A. I'm sure I even saw it on the spec sheet at some point (the 9C) - can't see it now.
Posted : 10/08/2021 7:48 pm
It’ll be fine. Also a 130mm fork at 20% sag is the same length as a 140mm fork at 25% sag.
Posted : 10/08/2021 8:04 pm
Not that it helps the op but having recently joined the bird Facebook group there’s a couple of posts on there about running the aether 9 with a 130 fork but also a shorter stroke shock (210x50 instead of 210x55) to give 118mm rear travel so I’m sure it will be fine with standard shock and 130 fork
Posted : 10/08/2021 8:14 pm
Can’t imagine it would be an issue - it’s only 10mm less. Will slightly lower your stack and lengthen the reach / steepen the head angle but minimal. Just stack some spacers under your stem if you have enough steerer to do it.
Or just buy a longer shaft - it’s a cheap thing to buy and not too difficult to change for a home mechanic.
Posted : 10/08/2021 8:17 pm
