Bikepacking seatpac...
[Closed] Bikepacking seatpack and reverbs ?
Planning some stuff this Spring, and will be using my Soul, which has a Reverb, and a Revelate Pika seatpack.
I'm thinking the attachment webbing for the pack will be likely to scuff up the reverb stanchion so I'd be better popping on a fixed post for the adventures....
Not a huge PITA as it's externally routed anyway, but wondering if there are any simple workarounds ?
Posted : 13/01/2016 11:34 am
Postierich mounted a second (cut-off) seatpost behind the dropper and fixed a bag to that.
However, you are unlikely to be dropping your seatpost with a bag attached (wheel/bag interface) so temporarily fitting a fixed seatpost would be fine for most folks.
Posted : 13/01/2016 11:36 am
I've run one with a Wildcat Tiger harness - not too dissimilar to the Pika - on a small drop Reverb with and quite a bit of post section exposed with no issues. But, the bag was attached to the post section.
Only reason I used it was for riding in the Lakes, where more often than not you do want to get your seat down for descents.
FWIW, I probably wouldn't bother again. But I'm happy enough riding with my saddle in the middle of my chest on steep descents.
Posted : 13/01/2016 11:42 am
cheers, will probably just swop over
Posted : 13/01/2016 11:46 am
i've covered the reverb stanchion with a small bore foam pipe cladding for a short trip. saves the hassle of removing and refitting a stealth reverb.
Posted : 13/01/2016 11:50 am
I've used a Wildcat Tiger seat harness for some trips on my Reverb without any obvious problems, you just have to remember not to drop the post ๐Ÿ˜€ Don't know what the strap on the Revelate is like in comparison to the Wildcat though.
Posted : 13/01/2016 11:54 am
Pics from different trips
[URL= http://i152.photobucket.com/albums/s189/ben_p1/5F867446-F64D-43AF-8AE6-1A57A3FEA29A.jp g" target="_blank">http://i152.photobucket.com/albums/s189/ben_p1/5F867446-F64D-43AF-8AE6-1A57A3FEA29A.jp g"/> [/IMG][/URL]
[URL= http://i152.photobucket.com/albums/s189/ben_p1/D0532693-9555-4843-809C-78719B6874E4.jp g" target="_blank">http://i152.photobucket.com/albums/s189/ben_p1/D0532693-9555-4843-809C-78719B6874E4.jp g"/> [/IMG][/URL]
[URL= http://i152.photobucket.com/albums/s189/ben_p1/F36756B5-9332-4CA6-AAF9-E21B29726FD2.jp g" target="_blank">http://i152.photobucket.com/albums/s189/ben_p1/F36756B5-9332-4CA6-AAF9-E21B29726FD2.jp g"/> [/IMG][/URL]
Posted : 13/01/2016 11:57 am
I can still drop the seat a couple of inches with the seatpack attached, though still lots of undroppable section left
The only reason I have it like that is because I can't be bothered to faff around with taking the seat on and off the post.
I usually drop the seat for rocky/techy descents when I'm bikepacking and have the reverb fitted
Posted : 13/01/2016 11:59 am
ben - thanks for pics - is that just a old towel or something ? have you found any scratching/abrasion to stanchion ?
Posted : 13/01/2016 12:02 pm
Wrap protect stanchion and fit the enduro collar to limit travel ๐Ÿ™‚
You need to take the collar with you anyway, in case of post failure imho, so you may as well use it.
Posted : 13/01/2016 12:19 pm
^^^^ yeah, the collar lives in my pack anyway ๐Ÿ™‚
I hadn't thought of that though - could use some clear duct tape round the bit above the collar which wont be going into the sleeve.....maybe less faff than removing and swopping over... will have a wee look later and see if pack fouls the hose/barb area etc and see what amount of drop I could still use, cheers
Posted : 13/01/2016 12:21 pm
Another vote for the collar- I was still using about half the reverb travel with an alpkit shaped bag. The only attachment to the post was a velcro strap wrapped very tightly round the collar. I don't think it would have been stable with a much heavier load than some clothes though.
Posted : 13/01/2016 12:24 pm
One is a cloth bag, and the other is a chamois from the car. I meant to make something specifically for it, but never got round to it
The chamois is because I forgot the piece of material I was going to use and I had that in the car! The cloth bag is a small bag that I can wrap around the post, and between the hose and post, without any issue. No marks on the post at all.
Saying that, I didn't use it last weekend - for Friday at BPW and Sat/Sun bikepacking at the Bear Bones Winter Event, where it would have been handy - as it's developed some sag so has gone back to SRAM. Doesn't seem to be related at all, and it happens on plenty of other posts anyway
It's definitely less faff with a normal seat post, but it's more faff taking it off/on. Also then get the benefit of a minor seat post drop. For a couple of sections on the bikepacking trip I actually dropped my seat manually - rocky descent and a dodgy looking ford
Posted : 13/01/2016 12:25 pm
thanks ben, great info, cheers
Posted : 13/01/2016 12:33 pm
Wrapped mine with closed cell foam and only fixed the seat pack to the saddle rails. Was still able to use the Reverb for most of its' travel
Posted : 13/01/2016 2:00 pm
Sorry for the digression, but...
What's the rear mudguard in that picture? Happy with it?
Posted : 13/01/2016 7:10 pm
For the twenty minutes it takes to change my stealth post over, I wouldn't risk it. And that bit of rag wrapped around the stanchion has the potential to hold grit and water against the surface.
Posted : 13/01/2016 7:15 pm
Thats a zefal deflector mudguard
Posted : 13/01/2016 7:52 pm
Yep, it's the RM29 mudguard. Very happy with it. Looks nicer than a mudhugger in my view, cheaper too
So happy with it I bought a second one to run on my rigid SS El Mariachi - has a proper front and rear mudguard for winter slop
Posted : 14/01/2016 3:16 pm
 Andy
This has got me thinking as I have swapped to normal seatpost to run a dropper, as I dont like the idea of something rubbing against a dropper post stanchion. But following Posties idea there needs to be an adaptor for dropper installed seatpacks. Something like a bar that runs from the saddle clamp bolts or saddle rails out, down and under the seatpack. Off to the shed this weekend if I get time ๐Ÿ˜€
Or just use a beam rack
Posted : 14/01/2016 4:26 pm
Before i had a proper seatpack i used a carradice saddlebag support to help hold a drybag, would have worked ok with a reverb (saddle rail space might be an issue on some saddles though).
[url= https://farm7.staticflickr.com/6151/6133387055_6b5842d677_b.jp g" target="_blank">https://farm7.staticflickr.com/6151/6133387055_6b5842d677_b.jp g"/> [/img][/url][url= https://flic.kr/p/akZdhF ]Prep[/url] by [url= https://www.flickr.com/photos/dickyelsdon/ ]Richard Elsdon[/url], on Flickr
Posted : 14/01/2016 5:09 pm
I wrap mine with a piece of innertube, with zipties both ends, worked for me ๐Ÿ™‚
Posted : 14/01/2016 7:40 pm
worked for me , was a week of bike packing and normal trail riding so was switching over a few times ๐Ÿ™‚
one bolt USE seat post
[url= https://farm8.staticflickr.com/7653/16646630063_40625b7202_b.jp g" target="_blank">https://farm8.staticflickr.com/7653/16646630063_40625b7202_b.jp g"/> [/img][/url][url= https://flic.kr/p/rn1kaa ]Untitled[/url] by [url= https://www.flickr.com/photos/nzrich/ ]Richard Munro[/url], on Flickr
Posted : 14/01/2016 7:54 pm
