Bikepackers & t...
[Closed] Bikepackers & tourers: saddle bags and dropper posts together?
 wl
Planning some touring/bike packing and thinking about one of those saddle bag thingies from Alpkit or someone similar. Do they work ok with dropper posts, specifically a reverb Stealth? Are they fine so long as you don't operate the dropper? Any info of tips welcome, as would be recommendations for kit. Ta v much.
Posted : 03/05/2016 12:13 pm
 DPM
yep - fine, just don't drop, and protect post contact points (and entire rest of bike) with tape.
[img][url= https://farm8.staticflickr.com/7357/26694452012_a10323b591_z.jp g" target="_blank">https://farm8.staticflickr.com/7357/26694452012_a10323b591_z.jp g"/> [/img][/url][url= https://flic.kr/p/GEU3yC ]Kit and Faff[/url] by [url= https://www.flickr.com/photos/13705182@N03/ ]Debbie[/url], on Flickr[/img]
Posted : 03/05/2016 12:18 pm
I use my Alpkit tapered drybag with my Stealth Reverb (150mm I think), and use the full travel. Bag is attached with a bungee through the seat rails and straps through the webbing loop round the static part of the seatpost and the frame. Might not work totally stuffed mind.
Posted : 03/05/2016 12:29 pm
I've bodged a Wildcat Tiger to work with a KS Lev - again, you just need to think about what is going to move what way - then adapt the strapping.
Posted : 03/05/2016 12:36 pm
I use my saddle bag/harness with a Reverb occasionally but don't operate the dropper. My wife uses hers with a dropper all the time, again without operating the dropper.
The only concern I might have (nothing to prove that this might be the case) is the strap around the post scratching it if dirt gets there.
Posted : 03/05/2016 12:51 pm
 wl
Thanks for these replies. Sounds like it shouldn't be an issue then.
Northwind - do you just use the dry bag instead of an outer, like Alpkit's (currently out of stock) Koala? Seems like a good option of saving dosh and weight.
Greg - what's the Wildcat like, any good?
Posted : 03/05/2016 1:00 pm
Revelate Viscacha with a Reverb. Can't use all of the travel but it'll drop enough for it to be a help
It has 2 velcro straps that go round the seat post. I just use one to give it a bit more space
[URL= http://i152.photobucket.com/albums/s189/ben_p1/F36756B5-9332-4CA6-AAF9-E21B29726FD2.jp g" target="_blank">http://i152.photobucket.com/albums/s189/ben_p1/F36756B5-9332-4CA6-AAF9-E21B29726FD2.jp g"/> [/IMG][/URL]
Posted : 03/05/2016 3:11 pm
