Bike Weight?
[Closed] Bike Weight?
 jedi
been there, smiles to miles wins 🙂 🙂
Posted : 08/04/2011 8:29 pm
I know how much my bikes weight and like to ride a reasonably light bike while still enjoying it. I've got no skills and pretend to ride something that could be classed as XC at most so I buy parts for that type of riding. XT + RS Reba + some reasonable finishing kit builds into a 25-26lbs steel HT which is light enough for me.
My OH's brother races a lot and has a 09 Epic that is 4lbs lighter than my HT. He's a skinny racing snake with no excess fat so saving weight on his bike does make a difference.
As for road bikes 19-20lbs is as light as I want it to be for my weight. I had a go on a 17.5lbs bike and it felt very fragile and not that much quicker than my steel road bike.
I just buy parts that work and will never buy weightweenies bits like aluminium cassettes and carbon fibre chainrings but if someone can afford them and wants to buy them then go ahead if it makes him happy. I'm always happy after a ride so I think I'm doing it right.
Posted : 08/04/2011 8:43 pm
if you race or you ride at a good weight then there is something to it and at the other extreme there is no point having a super heavy bike.
That said plenty of MTB are some way from a racing weight yet they think nothing of spending £50 to save 10 grammes. Utterly pointless as you still have to lug your fat lardy ass up the hill 😉
I care but not excessively
Posted : 08/04/2011 8:46 pm
Yep I care, but wouldn't compromise functionality. Being light there aren't that many parts I seem to break luckily, so it's not much of a compromise!
White components nearly always weigh more, as you can't anodise white.
Posted : 08/04/2011 9:52 pm
Scienceofficer - Member
If I can get lighter and can afford it, whats the big deal? Is this Kilogram envy?
It's just the poor people trying to act like they don't really care.
Posted : 08/04/2011 9:55 pm
I've a Specialized Enduro which weighs 27lb and a Marin Wolf Ridge that weighs 33lb.
The bike that's the least tiring on a long ride is actually the Marin...the only thing the Enduro does better is climb.
Suspension performance and geometry have as much to do with it as outright weight savings.
Posted : 08/04/2011 10:00 pm
Ok,
light bikes are better in my opinion - I am faster / better climbing and able to ride for longer on my light bike than my heavier built bike - but both are fun to ride in different circumstances - but IF its going to be a long, long all day epic xc in the hills ride with a few hike a bike sections I will always take the light one and make a compromise on the descents - WHICH is a built in safety factor - if i mince the descents I am less likely to hurt myself and put me / buddies in a pickle...
Anyways - to those who say weight doesnt matter should take a big ride with a lot of carrying and pushing and see how they feel after that !
Posted : 08/04/2011 11:02 pm
 7hz
faastmoto
I think about that 30-40lbs weight is normally for a bike. Its easy to run and balancing.
13 to 18kg... 13 is starting to get heavy to me, 18 is just outrageous.
10kg (22lbs) is my target, not sure what weight my bike is at the moment, but it is quite light (Cannondale hardtail, 1x9, XT).
I still think some things are worth the weight. I run 2.4 tyres and lock on grips, for example
mrmo -
Like everything diminishing returns does play a part. Then again i am of the opinion that 140mm is pointless for the majority of riders and they would be better off riding something more appropriate for the riding they do rather than believing the latest industry fad.
Diminishing returns do come into it. It's like the jump from XT to XTR for saving about 4% weight... not worth it unless you are racing and in with a chance of winning.
Or you like bling 🙂
Agree with the suspension thing as well, short n stiff is better 🙂
grannygrinder
it would be a far bigger benefit to loose 1/2 a stone off your person than loose 1000grms off your bike
1/2 a stone is about 3kg, so yes it is worth loosing that off yur belly rather than 1kg off the bike.
However, if you can save a few kg of off your bike for not too much cost, or can afford to go for it, then I don't see why not. having a 2 or 3 kilo lighter bike is always going to be more fun. And it isn't an either / or thing either... loose yourself 1/2 a stone off your belly and 1500 grams of the bike, and fly up the hills! That's the equivalent of 4.5 litres of water jettisoned!
Posted : 08/04/2011 11:40 pm
Cracks me up that Stans rims have different weights depending on the colour - white ones weigh 15-20g more than black
White bikes/components are always the heaviest as the paint has to be slightly thicker than the darker colours. I'm surprised it's that much on something as small as a rim though. Black (for carbon bikes) and silver (poilshed metl bikes) are obvioulsy lightest. Yellow and pink are also fairly heavy. Black and dark blue and green are fairly light
Posted : 09/04/2011 9:58 am
 IanW
Im lucky enough to have several bikes. The best, most fun and nicest to ride xc is a 20lb ss.
Posted : 09/04/2011 10:20 am
 jonb
It's a factor when I'm buying components but so is cost, durability and end use. There's no point carrying unescessary weight around. All things being equal* I will pick the lighter component if I have the choice.
I don't understand upgrades, replacing one perfectly good working component with another that's only marginally better. Wait till it needs replacing and then consider the options.
*Things are rarely equal (Stong, Light, Cheap - pick 2)
Posted : 09/04/2011 10:40 am
i care about weight because you feel the difference but always run decent rubber and saddles because there important.i weight 73kg and im 6ft3 so i think i couldnt lose anymore weight with out significant power loss.my bikes are some of the lightest in the uk nps but theyre still great to ride and on hills you can tell...
my side
Bruce
Posted : 09/04/2011 11:13 am
Only time I 'notice' the weight of my bike is when lifting it over the gate at work - that said, doing it a couple of times every day has gotta be good training for all those fences and stiles en-route to Cwmcarn. Reckon it weighs about 30lb but I've just replaced my air shock with coil so maybe a bit more . . . I'll check . . .
Hmmmmmm . . . 32lb . . . guess I'll be slower around the Twrch this afternoon then - more time to catch the sun I reckon 8)
Posted : 09/04/2011 12:31 pm
Like everything else it can go too far, but, when I stuck my 729s and dualplies on my Mmmbop it stopped being any fun to ride, just became a sledge. The Hemlock with its Lyriks in is harder to move around than it is with its Revelations. And I can put my rigid XC bike places I can't put either of the other 2 just because of its ridiculous agility and willingness to leave the ground.
I wish I could get the Hemlock back under 30lbs as it's lost a little of its playfulness but the tradeoff of the weight is worthwhile for the job it does. If it was just doing red routes and XC and stuff I'd say it's too heavy. Everyone strikes their own balance that feels right to them.
So yeah, I weightweenie to some extent, my main bikes have XTR cranks, a lot of thought goes into this part vs that part when I'm buying (but I've never replaced a seatclamp to save 10 grams! I've just bought the lighter seatclamp on day one) and I spend a lot on wheels.
Posted : 09/04/2011 12:44 pm
on a mountain bike, i would say tyre choice makes more of a difference than a few lbs here or there... obviously, a 22lb bike is going to accelerate and climb better than a 32lb bike, but some tyres just seem to make the bike feel so much more 'alive' and fast rolling.
Posted : 09/04/2011 12:50 pm
Black rims are normally anodised, white has to be painted and is thus heavier.
Posted : 09/04/2011 3:49 pm
Personally, I couldnt give a toss what my bike weighs. I think I have enough midle age spread to lose before spending extra on my bike. I've had lighweight bikes, and big ol' munters, but the enjoyment factor for me isnt solely about how the bike feels, its actually being out there in the fresh air, just riding. The bike is only one factor - I enjoy being out walking too, but don't stress on how heavy my boots are - its more about whether they fit properly, and whether they are up to the job.
On any build I do, I tend to go for sensible, durable components, before looking at their weight. My usual considerations are function, durability, price, weight and form. usually in that order, but sometimes I see something that makes me think "WOW - I MUST HAVE THAT", and this is where form overrides all the others.
Posted : 09/04/2011 5:14 pm
From my experinece although my Ti HT feels livelier at 25lb ish I reckon that for getting around a trail centre or even a natural XC route my heavier, 29lb ish BFe will overall be quicker despite extra weight due to faster down hills and more easy to ride latter through rugged stuff; too light a bike can be knocked off line too easily, wider tyres will roll through rough bits more smoothly---or at least thats what I think / find from these 2 bikes. Doesnt mean to say teh lighter bike isn`t fun to ride though
Posted : 09/04/2011 5:24 pm
Someone in a similar thread mentioned the stiffer, longer etc bike viagra approach there is at the moment. So true. I agree with the bike anorexia idea too.
Isn't there the idea of rotating weight vs static weight having a bigger effect on performance (lighter wheels>lighter bar/seatpost). I have also heard the point made of sprung vs unsprung weight as the suspension is helping to bear the load.
I personally have 2x9 on my bouncer for clearance and usability, 3x10 would be a waste of weight, space and money. I did splash on a gravity dropper which has definitely increased the smile:mile ratio!
Handling is not purely defined by weight (or cost), although it obviously has a strong influence. I quite like the option of weight shaving through second hand upgrades, we can't all afford to [s]spunk[/s] spend £55 on a seatclamp!
Posted : 09/04/2011 6:12 pm
1. Diet.
2. Haircut, Nº1 all over
3. Get fit.
Only when the above have been achieved and Merida are knocking on the door with a contract will I worry about bike weight, obsessively. 😉
Posted : 09/04/2011 6:20 pm
The problem with weight watchers is it hard to go back to a porker.
Posted : 09/04/2011 7:02 pm
 GEDA
When you pay for light weight stuff are you paying the same product but made from lighter but worse materials? I just say this as a lovely light weight sram rear mech I had bent, stepped the threads instead of the mech hanger breaking as it seemed to be made out of cheese. How many forks have rubbish internal made of plastic or light alloy that break all too easily. I like light but not at the expense of duribility, fun and too much cost.
Posted : 09/04/2011 8:01 pm
Just ride more and get fitter simples
Posted : 09/04/2011 9:26 pm
hambl90 - Member
Doesn't matter how fit you are, a light bike always reacts different to a heavy bike, just physics really. Some people obsess about going up, well tbh I don't mind dragging a bit of extra weight up the hill but I don't like it much going back down.
Posted : 09/04/2011 9:28 pm
I weigh my bikes.
Mainly because I can.
Try and get rotating mass down.
But I really don't mind weight that works, a brooks saddle on a long distance road bike for example. It may weigh 200g more but after 100 miles of no arse bother It's worth the weight.
Posted : 09/04/2011 9:42 pm
 br
Another advantage of a light bike is that you can add weight (for a reason), and its still not a heavy bike.
I sent my Thor's away for a service and stuck a pair of 36's in my 456Ti, its still a light bike.
Posted : 09/04/2011 9:44 pm
Sticking SB8's on transformed my bike. Can't wait to get some on the 29er.
Posted : 09/04/2011 10:10 pm
I'm a hefty forty-odd yr old rider, riding my 22lb Whyte two or three times a week. Always with a lot of climbing and never compromising on fast descents. I do obsess a bit over bike bits but believe that quality lasts. I rarely break stuff.
At the end of the day the bike is fast and responsive and makes me grin, regularly.
Posted : 10/04/2011 12:10 am
I did start off by trying to lose weight from my Wolf Ridge and successfully got it down to sub 30lb. I realised that I was trying to make the bike something it wasn't and in doing so compromised a lot of solid feel of the bike, which was the reason I bought it in the first place.
I transferred the lightweight kit onto my Enduro and am pleased with the result. I have two completely different bikes for different purposes, with a 6lb weight difference between them.
However, it always surprises me just how much difference in my post ride fatigue can be attributed to tyre choice and suspension efficiency, as opposed to whether I'm carrying the weight of a decent takeaway around with me or not.
That said, if I could have a Wolf Ridge that weighed 26lb and packed 160mm forks at a less than ruinous financial penalty then I probably would snap it up.
Posted : 10/04/2011 12:48 am
Page 2 / 2
