There are some bits of kit (components and riding kit) that you own that you know you should throw away and replace, but you just keep on using them.
Maybe just old.
Maybe a little broken, but not so much that it's unusable.
Maybe so smelly, old and holey that it's only worn as a base layer on special holidays.
For my part I give you the Franken-catcher....
[url= https://farm5.staticflickr.com/4447/37855470962_e41e33f7df_b.jp g" target="_blank">https://farm5.staticflickr.com/4447/37855470962_e41e33f7df_b.jp g"/> [/img][/url]
[url= https://farm5.staticflickr.com/4453/37838339406_94e2cd0090_b.jp g" target="_blank">https://farm5.staticflickr.com/4453/37838339406_94e2cd0090_b.jp g"/> [/img][/url]
It's actually a combo of 2 different versions of the rear Crud-catcher. The back part fell off one, and then I found the back part of another one on the trails.
Aha, I thought one rainy day, I'll put them together.....nope, non-compatible models and won't play ball. Well nothing a drill and some zip ties won't cure.
That was about 6 years ago 😆 and it just won't die. Honestly, I've tried!
I've also got a 1994 Lusso top somewhere. It's a cool looking top, but I only have to wear it for 10 minutes and it warms up and I remember why I don't wear it all the time! Mmmm, 20 year old sweat.
my blue franken-windshirt. A buffalo windshirt that has done service all over the world since early 90s. it's so UV damaged that it tears easily and has been sewn together endlessly. Love it.
Not me but my mate has a similarly held together crud-catcher with several old shoe laces attaching it to itself. When he finally got rid of his ancient Marin last year for a brand new, top spec Orange 5, the first thing he did - was attach the same bloody crud-catcher!
This is probably my best example. A pair of cheapo fakeleys with prescription lenses which I use for night riding. They've been crashed/dropped and broken at least three or four times and are held together with Sugru. Still going strong!
Character innit.. Nothing worse than a brand new pristine bike.
Me - the rider. The rest of it works quite well.
I've got a green one same issue year as that too!
I still use a Blue Iridium lens that came on a pair of Mumbos. Yep, before they became M-Frames.
One of my bikes has a set of 1995 Marzocchi DH3 forks on it. Although they're actually in better nick than my newest ones which are 10 or so years old.
I have an orange evo4 hard tail ,26"wheel , old standards etc. A total triggers broom ,bar the brake levers. Every year I have the conversation with myself that I should retire it
But it's too much fun . And still works !
#tightarse
Middle front chainwheel on 26" commute bike is so worn I have to pull away on the granny ring to prevent chain slip. Discovered on this mornings commute the front derailleur has now given up due to cable fray. Luckily had planned an easy ride so not a problem. Gives me an excuse to ride the FS tomorrow.
My Lab Gear merino. They were all the rage on here circa 1985 but the garment seems to have lasted longer than the company. Full of holes but refuses to die.
My patagonia base layer bought it on a work trip to the states in 2004, still my favourite, still in one piece. Love it comfort baselayer
My SPD shoes are held together with ductape.
I ride in them because I've actually ridden/walked through the soles of my 5.10 (still wearing those today actually)!
Bar tape on the roadie has worn through on the bend/hoods.
Pair of Royal gloves.
Summer gloves bought a few years ago- both thumbs have holes, the palm is now half rubber from the gribs, the top is faded & some tears from thorns. They are comfy and do the summer job well though, so they shall stay.
My 10 year old ground effect soft shell.
The zip pull tab is broken off so I have to pull the zip up with my fingers. It has a couple of holes and isn't windproof anymore.
It's still my go to cold weather riding top.
Di Marchi roubaix bin 3/4. Older than my teenagers, saggy, but soooo warm under my baggies when I occasionally see fit to go off road.
I still have a Labgear merino that I bought in Australia. Comfiest top I have ever had and like yours a little holey now but I cannot bring myself to get rid of it.
Dogsby
Sunn t-shirt from 1993 (green with white and orange swirly Sunn logo), more holes than material these days.
Same thing has happened to a 15 yr old Altura jacket of mine - I replaced it with the circular clip part of a key ring, but small zip ties work too.
Gore 3/4 bibs. They can only be worn under things due to the 1” hole above the crotch and numerous others all around. Still comfy so I keep them.
2004 pair of specialized bg gloves I found to ride to work this week.
All of the grippy rubbery cover has disintegrated and the gel pad gone solid. Didn’t realize in the dark what the issue was but couldn’t get out of the saddle as the material underneath was shiny shell suit stuff and my hands would slip off the bars.
1996 hope big in that's just been moved to its 6th bike. (An ibis mojo no less)
My Vaude rucsack - 1997 vintage, still refuses to die...worn, stained, reflective stuff all worn off, missing some of the back, but still going.
1999 Karrimor Goretex Paclite jacket I bought from All Terrain Cycles when they were in Crosshills. Still pack or wear this on my local rides. Mainly showerproof now but still serves a purpose. Paid £130 back then - yikes!
Salomon rucksack from 2000ish, used for running and biking, zip doesn’t completely close as I had to sew it together, on my third bladder, bought and Evoc to replace it but just go back to the Salomon
1989 specialized top. So old it's almost retro cool. If it weren't for the tool wearing it...
Some (2008?) 661 Raji gloves that my fingers now poke through. Easier to unlock my phone now though.
some fox gloves. taped and stitched the fingers so many times until there was more tape and stitching than original material so chopped the fingers off and now use them as mitts.
I find good fitting, comfortable gloves hard to find.
1988 Stiff Little Fingers sweatshirt.
Wore it on a ride over the weekend.
Finally starting to fall apart, has holes from creosote, but still just about ok over a base layer.
Macpac hydration pack. Bought on a trip to nz in 1999
I've a polaris windproof smock top that randomly appears. I think I bought it in 1995.
Until very recently my SPD shoes were some 661 launches from 2004/5. The outer coating had some off, so they looked like cotton wadding held together with shoelaces & velcro.
Just dug out an old set of Nite Flux lights for this winters riding.
They are 17 years old, and admittedly only used during winter months, but tested them last night and they 'ran' for 3 1/2 hours on full power.
