Bike shed lighting
[Closed] Bike shed lighting
For various reasons too boring to go into, I can't run mains to my garage/bike cave. A few years ago I bought some fluorescent rechargable strip lights. They're OK, but hardly super bright and the cheap SLA batteries in them are giving out. Like this:
Can anyone recommend something similar? There must be something decent using LEDs with a battery that dosn't expire after a few recharges now?
Google gives loads of possibilities, but it is real-world experience of a specific product I'm after ...
Rechargable from the mains rather than messing about with solar panels and 12v bateries please.
Posted : 27/09/2012 12:52 pm
http://www.amazon.co.uk/Rolson-Tools-60702-Magnetic-Lamp/dp/B001B4PINI/ref=sr_1_1?ie=UTF8&qid=1348751551&sr=8-1
http://www.amazon.co.uk/Sanyo-Eneloop-Pack-Batteries-HR-4UTGA/dp/B004JUZGCE/ref=sr_1_4?ie=UTF8&qid=1348751558&sr=8-4
Buy as many of these LED lamps as you think you'll need and use Sanyo Eneloop AAA's as they're low self discharge and work the best in low temperatures.
Posted : 27/09/2012 1:15 pm
Er, I'd rather have one big strip light thing for the entire space. Eneloops are good, but I'd rather just plug it into the wall overnight once a week ...
For scale, the units I have are twin 2ft fluo tubes.
Posted : 27/09/2012 1:19 pm
diesel generator?
Posted : 27/09/2012 1:31 pm
Poss a touch OTT 😉
Posted : 27/09/2012 1:34 pm
Have you costed up some replacement batterie for what you have? Also, a quick look at EBay has 600mm LED fluorescent tube replacements at £13.50 each. That plus new batteries (or a single leisure battery you charge every few weeks) would really make a far longer lasting solution for the cave. You could try it with one of them and see how it goes.
Posted : 27/09/2012 2:40 pm
adh, they did have petrol ones for about £70 in lidl or aldi not long back, I forget as I go in so many bargain cut price establishments they meld into one... You neighbours will love it.
Posted : 27/09/2012 2:51 pm
I did consider it TT, but rejected the plan on grounds of extreme lazyness. That and I fancy more lumens and something with a pullcord for short arse persons such as myself.
Posted : 27/09/2012 2:58 pm
Couldn't you get some led light units strung up to a leisure battery?
Should get plenty of run time from the leisure battery & just bring it back in the house every so often to charge...?
Admittedly not very off the shelf, but something I was considering when we were looking at house with a garage in a black away from the house. Luckily, sense prevailed and I got an attached garage with power!
Posted : 27/09/2012 3:21 pm
There was a thread a while ago on this, think you could use a wind generator thing they use to top up leasure batteries on boats or solar panels...
Not cheap!!
[url] http://www.windtrap.co.uk/generate-electricity/wind-turbines/rutland-504-wind-turbine/ [/url]
Solar, this might be better.
[url] http://www.windtrap.co.uk/generate-electricity/solar/solar-mate-1/ [/url]
Posted : 27/09/2012 3:29 pm
 cp
Cover the roof in alu foil and point a couple of ebay/dx XML or P7 bike lights at the roof, with a little fan next to them for cooling 🙂
Posted : 27/09/2012 3:34 pm
I've got one of these.
[url= http://www.clasohlson.com/uk/LED-Work-Light/Pr182051000 ]LED light[/url]
Its very bright, one is more than enough to light up your personal space and maybe 2 or 3 to light up the whole garage. Its very durable and well made, never used the battery till flat so not sure how long they last but managed to get 2 hours of it no problem. Also seen very similar ones in hardware and DIY stores
Posted : 27/09/2012 4:23 pm
I was going to say get an old car battery, solar panel, charger and some LED lighting. You can also run a small tyre inflator off the battery for tubless duties 😀
Posted : 27/09/2012 4:46 pm
I've got one of those 60 led beasties that jairaj has for my garage. Simple cheap, easy and bright. If you need more light then get more than one.
Posted : 27/09/2012 5:29 pm
Like andyl suggests above Ive got a leisure battery ( caravan battery ) connected to a small solar panel on the roof of my shed controlled via a regulator. I have a 240 v inverter which can push out 300watts with this have 2 240v compact connected to 240v 9 watt fluorescent bulbs. Whole set up cost approx £200 and i learnt a whole lot of about off grid electrics in the process.
Posted : 27/09/2012 10:12 pm
