Bike pumps
[Closed] Bike pumps
[#11545830]
Do I need a separate pump for when I’m out on the bike, another to adjust my shock and another to inflate tubeless tyres? Is there a mini pump that does tubeless tyres when you’re out and about or is it only a CO2 canister that can re-inflate a tubeless tyre? Sorry for the newb questions.
Posted : 15/12/2020 8:04 pm
You should be ok tubeless unless you burp it off the rim! Shock pump for in back of car once you've go it dialled.
Posted : 15/12/2020 8:49 pm
@konanige Okay, thanks. So I’m right thinking that you really need 3 separate pumps then?
Posted : 15/12/2020 9:47 pm
Yes, at least 3 ! And a<span style="font-size: 0.8rem;"> CO2 inflator, but OneUp have a mini pump which has a built in inflator and you can store a CO2 cartridge inside it.</span>
Posted : 15/12/2020 10:07 pm
I’ve never got on with co2 cartridges. Used them on the road bike the odd time but prefer a pump on the mtb. I’ve a mini pump that comes with me on the bike, a track pump with large volume chamber to seat tubeless at home, and a shock pump. The track pump gets used most of the three. Can’t remember the last puncture I had on a ride. Even if you burp a tubeless tyre they usually seal again and just reinflate with mini pump. If the bead comes off and doesn’t reseal I’d be putting a tube in.
Posted : 15/12/2020 10:20 pm
