Bike kit help
[Closed] Bike kit help
Hi guys,
I have my first sportive in two weeks time and I barely even have a working bike yet! So there are a few essentials that I think I need to get and I was hoping some of you could help advise.
Saddle Bag
Something like the Profile bag? [url= http://www.wiggle.co.uk/profile/saddle-bags/ ]http://www.wiggle.co.uk/profile/saddle-bags/[/url]
GPS computer
Should i go for something cheap that I can use for running as well as cycling - [url= http://www.runtheline.com/3425/polar-rcx3-gps-and-heart-rate-watch-review ]http://www.runtheline.com/3425/polar-rcx3-gps-and-heart-rate-watch-review[/url] or should i go for something exclusively for cycling [url= http://www.wiggle.co.uk/polar-cs600x-wireless-hrm-cycle-computer/ ]http://www.wiggle.co.uk/polar-cs600x-wireless-hrm-cycle-computer/[/url]
Helmet
Does the helmet that you buy really make a difference? I was planning on just getting as standard Met [url= http://www.met-helmets.com/Range2012/Catalogue/Range_2012_1/range_2012_1.html ]http://www.met-helmets.com/Range2012/Catalogue/Range_2012_1/range_2012_1.html[/url] but is there something else I need?
Cheers in advance
Posted : 30/05/2012 7:51 pm
 poly
Not sure why you think you need a GPS in a sportive at all? Unless its badly signposted and you are worried about getting lost? A cheap cycling computer will give you pace / distance feedback if you need it, but a decent sportive will have key mile points (say every 5miles) signed/marked if you want to save an extra 50g.
Can't comment on the specific saddle bag - but tube+multitool+anything else you hope not to need on the ride; anything else needs to be more accessible. I know even less about helmets except for visors being bad for long road cycles - think about what you can see when curled over with the helmet on, you don't want to tip your head back.
Posted : 30/05/2012 9:42 pm
GPS not needed
saddle bag useful but not necessary assumingyiu have a cycling jersey with pockets
better helmets tend to keep your head cooler and weigh less but aren't typically any safer. there are plenty of good ones cheap at Crc and the like.
Posted : 30/05/2012 9:47 pm
If you want to be competetive at a sportive then Id recommend a support car that carries all your supplies along with a spare bike incase of a mechanical.
If you're a lower class road rider who cant afford such necessities, then I'd recommend the Leyzne Micro Caddy (the small one) saddle bag.
It is very compact, doest rattle about about and can fit an inner tube, tyre levers, chain tool, mini tool and a patch kit.
Almost ideal.
Posted : 30/05/2012 10:27 pm
All you need to know is here:
http://www.velominati.com/the-rules/
So no saddlebags, just a little computer, and a nice light helmet or failing that a simple cotton cycling cap which you should wear only on the bike. Don't forget espresso!
Posted : 31/05/2012 8:18 am
