Best way to cycle f...
[Closed] Best way to cycle from Edinburgh to Aberdour
Hi
Whats the best route to get to Fife (aberdour specifically) on the road without having to go on any of the main roads. Only ever driven it.
A GPX file would be appreciated.
ta
Posted : 15/05/2014 11:56 am
there's a cycle path out which you can get on around haymarket which goes over crammond brig then up the side of the road to dalmeny then south queensferry (where it dicks about in housing estates on the way to the bridge, but is marked) then over the bridge the road east isn't bad, but there could well be a path there too
Posted : 15/05/2014 12:05 pm
Fife coastal path,does it not start from North Queensferry ?
[url= http://www.fifecoastalpath.co.uk/ ]Look here[/url]
I have only ever done the bits from the Tay bridge to Leven ,but I thought it went all the way to the bridges.
Posted : 15/05/2014 12:07 pm
national cycle routes should take you there.
have a look on here: http://www.openstreetmap.org/#map=11/56.0371/-3.3457&layers=C
pretty straight forward, and should be signposted.
Posted : 15/05/2014 12:32 pm
