It’s that time of year again when wet rides may become a requirement of getting out doors. I’m currently using muc off and it’s a truely disgusting liquid that coats my chain in what looks like black oil after 30 miles
I’m after something that keeps the drivetrain reasonably clean, without going down the waxing route (I wax the summer bike but can’t be assed with the hassle for winter)
I’ve read good things about Peaty’s . Anything else worth considering? It’s for the road and gravel bike if that makes any difference
ta
Don't buy Fenwick's All Conditions Lube. It was recommended somewhere but Lord knows why. My chain ended up covered in a seemingly endless thin black river of lube.
I find the Peaty's stuff works well and stays pretty clean. I have all 3 types not that the dry lube has had much use this year
Juice Lubes Viking Lube... Easily the best "wet" lube I've used. Not the longest lasting for sure, but the cleanest by a mile.
I have however since been converted to Squirt... A little more involved in that you need to use it from the start on a brand new chain and can't then mix with other lubes, but your chain will stay cleaner and better lubed than ever before!
Wolf Tooth WT-1 is terrible, biggest black mess I've ever seen the first couple of rides on a new chain with factory grease on. Still wipes off black on a cloth after a few hundred km.
Finish line Wet. Wipe a drop, from link-roller-link on each one individually. Takes a minute. Same goes for all of these. Get the right amount of lube in the the right places. If you just back-pedal the chain while spooging loads on, then ride through gop, then of course you'll end up with a snotty chain.
Peatys blue for a clean wet lube, I run that or Smoove when conditions are dry, so mostly Peatys this year.
Another vote for peatys. Wet and dry
3 in 1 oil. Never felt the need to use anything else. Gradually converting my friends as they admire my nice, clean drive train.
GT85... clean and lovely.
White Lightning Epic ride, its a lighter wet lube so maybe not as resilient for longer rides in truly gopping conditions but its easy to apply, doesn't attract the crud as badly as the thicker more dedicated wet stuff and much easier to wipe the chain down and reapply.
It's a bit of a 'Jack of All trades, master of none' but it works well enough everywhere in between 'sunbaked wasteland' and 'Scottish January'
Fenwick’s Professional. It needs a few hours to cure, but works well in the wet and doesn’t leave everything covered in black goop. I don’t understand how it cleans off so easily and endures in wet conditions.
Squirt (but as per other reply needs a properly clean chain to begin with - REALLY clean).
May not last as long innthe wet, but no black gunky Torrey Canyon slick left everywhere
prefer the fenwicks all condition lube to the pro stuff. £5 on merlin when in stock.
always liked rock n roll blue or red road too, also on merlin.
Finish line Ceramic Wet.
Great stuff. My favourite all-round lube, especially for road as it's so clean.
But for everyday use I'd suggest Weldtite TF2 Performance.
Way cheaper AND less sticky than most wet lubes and works really well.
I've just bought some of this to try having tried pretty much everything else. Although I haven't tried peatys yet.
Weldtite Unisex Weldtite Tf2 Teflon 100 ml Dry Wax, Green https://amzn.eu/d/eSSwWOb
Also getting fed up of black sticky mess and clogged up jockey wheels. Gritty paste on the chain and chain rings 🙄
I do one drop per link, cycle round, then wipe off excess and it still does it. I'm sure my chains ever did this year's ago and I used to just splash it on. It seems the more fancier the lube gets, the worse the black mess becomes.
If this doesn't work ill go back to a simple oil that worked for years, maybe even 3 in 1 or I'll buy a slow cooker and some wax as I seem to clean my chain after every ride anyway.
Pedro's Syn is a very clean lube, give it a go.
Still comes with a blue cap though, the sexist pigs.
I've given up with various lubes. Off the back of the MX/Enduro bike approach I spray the chain with WD40/GT85 and rub with a rag.
I've also bought 5l of this https://www.smithandallan.com/product/smith-allan-dw-40-wd-40-alternative-4046 which is the same stuff basically. I use it in my park chain cleaner every month or so.
I thought they must have misinterpreted what type of lube was required when I read the name of that stuff.
I've used loads, some are shit and don't last/wash off, some last for ages, biggest reasons (IME) for black gunk is either adding oil to an already dirty chain (they aren't hard to clean), over oiling (have you seen the price of lube these days?) or mixing lube type/delivery grease/wax.
bikesandbootsFull Member
Wolf Tooth WT-1 is terrible, biggest black mess I’ve ever seen the first couple of rides on a new chain with factory grease on. Still wipes off black on a cloth after a few hundred km
I have had same experience, which is disappointing given the great reviews it gets. Mine was applied to a clean and dry, degreased chain.
I'll be going back to Peatys Premium all weather I think.
Muc Off wet turns into black sludge, so use sparingly and perhaps wipe off any excess.
arogers
Free MemberStill comes with a blue cap though, the sexist pigs.
Ah, the good old Uni Sex Lube.
I had to make do with KY Jelly when I was an undergrad.
Rock n roll blue or gold for me. I just follow the instructions and it keeps my chains clean and lubed.
It's not officially a Wet Lube but I use Purple Extreme on all my off-road bikes. Applied sparingly it lasts well and doesn't produce a sticky mess. It can be hard to find so I bought 3 bottles last time.
Another juice Lube Viking user too! Best out there.
I am a few weeks into Juice Lubes Viking as well. Seems good so far.
Slightly O/T:
How's the best way to degrease a chain for using Squirt?
I did the last one in a tub with Guy Martin Proper Degreaser - left to soak and the gave a good scrub.
Cleaned up nice, but even when lubed with squirt I was getting stiff links (to many double entendre's with squirt, lube & stiff....)
If you already wax one bike then Putoline is a no brainer. One waxing will last ages and ages so it's really no hassle.
Mostly because I s**** when I look at the massive box of "Extreme Lube", but it's good. Cleans the chain well.
If you already wax one bike then Putoline is a no brainer. One waxing will last ages and ages so it’s really no hassle
id need another slow cooker as the one I have is fulfilled with molten speed wax. Won’t be using that on the winter bike given the cost
Silca Synergetic chain lube.
Might try UFO wet lube (although it's wax based) next time but my Silca bottle lasts far far longer than whatever I used before so probably costs the same for how long the bottle lasts.
I use squirt all year round. Just clean and degrease the chain as you normally would before applying. You don't need to over apply the stuff.
Zero Friction Cycling have torn Wolf Tooth a new arsehole about this lube:
Related question...what are people using to clean and degrease the chain before lubing up?
I usually use white spirit in a jar but feel like it might leave a residue which messes with the lube.
Related question…what are people using to clean and degrease the chain before lubing up?
Heavy duty water based degreaser and a park cyclone chain scrubber. I find the scrubber is very effective at brushing off all the crap.
Plus it is a lot less hassle than taking off the chain or storing and disposing of solvents like white spirits.
I’ve given up with various lubes. Off the back of the MX/Enduro bike approach I spray the chain with WD40/GT85 and rub with a rag.
My MTB gets a hosing off after each ride and then muc-off C3 dry applied to the chain and it always stays lovely and clean.
Surely this is a better compromise than resorting to using non-lubes on the chain - every wear/friction test result I have seen for WD40/GT85 has been horrible.
Whatever you choose, use a rag to remove all of the surplus after application. This pretty much eliminates the black grinding paste scenario & gunked up mess that can accumulate on the chain & jockey wheels. The lubrication takes place inside the chain, anything on the outside is simply attracting clag.
Use that for oiled chains. And a jar of white spirits for chains that are going to be waxed.
I mentioned this on another thread, get one of the IKEA portable induction hobs. Then you just need a cheap metal pan for each. And you get an induction hob to use for camping/cooking out doors too.
the fenwicks chain cleaning sponge £1.50 combined with the chain cleaner on merlin is great, will make your chain sparkle..
Doesn't tend to need it using the products I've suggested.
As above, I just wipe the chain after application, and I use dry lube when it's dry.
You've seen the test results for C3 yeah...
https://zerofrictioncycling.com.au/lubetesting/
If you have any belief in his testing an expensive bottle of lube used on a clean chain and kept on top of saves you an awful lot of money in the long term and is faster.
I think I must have really low standards as I use the Muc-Off wet lube and it seems fine to me. Whatever I use, the chain needs cleaning after a while. I do use it very sparingly though.
seem to really rate the Silca SS (Supersecret) and the slightly wetter Silca Synergetic - they are pricey but appear to last for ages....
any real world uk conditions views ?
Supersecret is wax and I gave up rapidly hotwaxing then topping up on the MTB due to conditions going from lovely to sloppy at a moments notice. Wax the road bike.
Synergetic is oil based and it's so much nicer than anything I've used before. Feels smoother, less gunk build up. Bottle so far has lasted 12months and probably used a quarter of it. The nozzle on mine is very fine so easy not to pour loads on which helps. Not the most prolific riding year mind but out in all conditions. This is based on using on a cleaned drivetrain. Would buy again and in theory that money is more than saved on less wear.
^^^ good to know, thanks, may give them a go when current Smoove runs out. I was using Wolftooth WT-1 as posted earlier on mtb and gravel bikes but have today degreased and cleaned drivetrains ready for something less messy. Have Smoove on road bikes and find it decent. Will maybe take a punt on Synergetic for mtb & gravel in that case
You’ve seen the test results for C3 yeah…
https://zerofrictioncycling.com.au/lubetesting/If you have any belief in his testing an expensive bottle of lube used on a clean chain and kept on top of saves you an awful lot of money in the long term and is faster.
I have belief in his testing, and will not be replacing the C3 after the bottle has run out - still, I don't think it is horrendous for my particular use-case for the MTB which is mostly 45 minute races without even bothering for a warmup lap 🙂
What I said I think still stands though, C3 dry might not be a good chain lube - but at least it is chain lube unlike WD40/GT85.
Stihl synthetic sawchain oil.
Completely different style of chain though. Motorcycle O/X ring chains have the lubricant sealed inside by the O/X ring seals, hence don’t need lube on the outside.
Wolf Tooth WT-1 is terrible, biggest black mess I’ve ever seen the first couple of rides on a new chain with factory grease on. Still wipes off black on a cloth after a few hundred km.
/blockquote>
Just removed this disgusting stuff from my drivetrain. Half disassembled it including having the cassette in pieces.
Couldn't make it up, company that makes money selling consumable drivetrain parts launches new chain lube which accelerates wear.
If for some reason you want my over 3/4 full 60ml bottle, it's yours for the postage cost.
Now trying Effetto Mariposa Flowerpower drip-on wax
Has anyone tried the Tru-Tension Tungsten All Weather Lube? After a couple of years of Putolene I'm fed up with the faff and looking for something simpler (and cleaner...)
Can't believe no one has said
Smoooooooooooooove
I keep going back to rock n roll extreme for a clean chain experience. It doesn't last long, definitely need to reapply after most rides, but it runs very clean.
Currently experimenting with peatys all weather on my commuter. It's a black mess by comparison. It does last well and it's lubricating qualities are anecdotally good.
Tried that wolftooth stuff, fabulous lubrication, another black mess.
I flirted with squirt. That just went all claggy as soon as the weather got cool and wasn't really all that clean either. Yes, I made sure I want over applying and letting it cure.
I'm going back to RnR once the peatys had been used. I'll have clean drive chains again. My jockey wheels won't be a sticky mess full of crap. It's easy to apply, which is lucky coz it needs doing more often.
After a couple of years of Putolene I’m fed up with the faff and looking for something simpler (and cleaner…)
I did this, as soon as I stripped the Putoline off I realised it was pretty much all that was holding the drivetrain together 😂 It barely ran despite a fresh application of Viking Juice.
I was back on Putoline within about 2 rides 🙄
I wanted to try chain waxing, and with my usual mission creep, ended up ordering a wax warmer and ulrasonic cleaner as well as wax.
I ordered some wax from "optimize" who do the solid hot melt wax as well as liquid waxes. The plan is to give the chain a wipe down and apply some liquid wax after wet rides in the hope that extends the time for requiring a hot wax application.
iaincFull Member<br />
seem to really rate the Silca SS (Supersecret) and the slightly wetter Silca Synergetic – they are pricey but appear to last for ages….any real world uk conditions views ?<br />Posted 1 month ago<br />REPLY | REPORT <br /> <br /> <br />tomlevellFull Member<br />Supersecret is wax and I gave up rapidly hotwaxing then topping up on the MTB due to conditions going from lovely to sloppy at a moments notice. Wax the road bike.
Synergetic is oil based and it’s so much nicer than anything I’ve used before. Feels smoother, less gunk build up. Bottle so far has lasted 12months and probably used a quarter of it. The nozzle on mine is very fine so easy not to pour loads on which helps. Not the most prolific riding year mind but out in all conditions. This is based on using on a cleaned drivetrain. Would buy again and in theory that money is more than saved on less wear.<br /><br />
I posted a month back on this thread, and swopped to synergetic as a ‘wet lube’ and SuperSecret for road as a dry lube.
impressed with both so far and won’t be changing.
@iainc (or anyone more knowledgeable than I am), why a wet lube for off-road rather than SuperSecret or one of the other drip-ons like FlowerPower or Ceramic UFO?
I'm on Molten Speed Wax currently on my road bike. Throughout the summer it has been awesome. I experimented with GLF wax (smells lovely!) also but that didn't seem to last anywhere near as long between waxes (no long term testing though but it needed doing every couple of rides so I swapped mack to the MSW). For the winter I plan to try topping up the MSW with Tungsten All Weather and/or Silca Super Secret depending on which turns out to be better (I bought a bottle of each 🙄🤷♂️). I really would prefer not having to go back to Putoline on my shiny road bike as the MSW is so so clean. Drivetrain looks like new still and I've done 6000 KM on it.
Currently using old suspension oil mixed with a bit of blue marine grease. It's significantly less shit than Muc-Off (although so is actual shit).
I like the idea but how do you keep the wax at the correct temperature?
Which leads me to ask ...
what capacity of slow cooker do you need for a chain?
I’m still persisting with Squirt. The longer I’ve used it, the better it seems to last on the MTBs, about to swap the commuter/gravel bike over too.
On both MTBs there is noticeably less build up on the drivetrain. Mostly they’re just a bit dusty when they dry out.
Revolubes, clean, lasts ages (bloody ought to given the price.
Works for me also in winter slop, thoughtl they also have some form of chain grease for winter - not tried that one
bikesandbootsFull Member<br />@iainc (or anyone more knowledgeable than I am), why a wet lube for off-road rather than SuperSecret or one of the other drip-ons like FlowerPower or Ceramic UFO?<br /><br />
I find it lasts longer in typical west of Scotland manky conditions than SuperSecret or other dry lubes.
ZFC's extensive body of work can be distilled down to 2 points.
1. Dry wax lubes are best, irrespective on conditions. Dry wax formulations are improving all the time.
2. 'Resetting' your lube to its fresh state, irrespective of wet or dry, is the key factor in its longevity. Waxes still have the longest reset intervals.
After a winter ride, I rinse down the drivetrain while spinning the pedals until the water coming off is no longer brown, then relube. I don't trust that any lube would survive the rinsing, so lasting one ride is enough for me!
@Scienceofficer what do you mean by “resetting”?
Remove contaminants/clean and relube. This does not include reapplying lube over dirty lube.
With wax this is somewhat easier because when heated it goes runny and all the wear particles and trail debris sink to the bottom of the heating vessel.
Wet lubes mostly need degreasing.
After a winter ride, I rinse down the drivetrain while spinning the pedals until the water coming off is no longer brown, then relube. I don’t trust that any lube would survive the rinsing, so lasting one ride is enough for me
Pretty much this is me with Peatys all weather premium.
I used to use pro gold before changing to Squirt, but I might change back over winter, it doesn't seem to gunk up as much as other wet lubes and you can clean the chain with it too, I applied it more regularly and wiped the excess off which did seem to bring the chain up cleaner, it's thin so gets deep into the links.
Not wet lube but oil based - Synergetic for example and no doubt there are other good ones out there I just haven't used them.
Drip ons like those above are wax based (I;ve no idea what Flowerpower is mind)
For me and my use I prefer the oil based offroad as it last better in intermediate conditions (full on muck means it gets washed off anyway afterwards). Probably the main reason is I invariably forget to reapply soon enough before the next ride and the wax based ones need to dry before use...
Doesn't his testing suggest that immersive waxing is best, or have I misunderstood, and that's what you call dry wax? And doesn't ZFC also say that after wet weather riding you should reset (i.e. remove containments and re-lube) every time? And if your choice is immersive wax, 1. How many on here are doing that, and 2. doesn't that remove a couple of the key benefits of immersive wax lubes - you don't need to do it that often, and because you don't need to do it that often, the cost is lower.
Doesn’t his testing suggest that immersive waxing is best, or have I misunderstood, and that’s what you call dry wax?
Good shout. My terminology could be better. I do mean immersive waxing. I used 'dry' to differentiate this from the drip on wax lubes.
Absolute optimum is to reset after every ride but after what ride length? ZFC has a table showing what lasts the longest in poor conditions as well as others. I think one of the immersive waxes is supposed to last about 200km between reset intervals which is the current absolute best tested at present.
Of course,ZFC has a huge aussie roadie bias. It seems pretty clear to me that they wont have much comprehension on UK off road winter riding conditions, so I should think the reset interval will drop significantly...
It's why I stayed with wet lube - easier to manage on a high frequency basis. I'm still curious about the immersive waxing approach - though I used Putoline BITD and found the hassle/return equation firmly in the 'nope!' category, things have moved on with hot melt waxes.
Ah right, now his comments make more sense! The way he talks about wet weather off road riding makes me think that if he came and saw what most of the MTB community here are doing here most weekends in the winter, he'd pass out.
though I used Putoline BITD and found the hassle/return equation firmly in the ‘nope!’ category, things have moved on with hot melt waxes.
Was my experience also, but if you're prepared to either un multiple chains or take the chain off after every ride, I guess the gains are there to be had. What price convenience I guess.
