best dropper stanch...
[Closed] best dropper stanchion Lube ?
For my forks I use Fork Juice before and after rides/cleaning. Having just got a new Giant dropper under warranty, due to the first one losing it's anodising after 2 gritty rides, I am keep to do some preventative maintenance.
Online stuff suggests unscrew the collar and apply 'grease', though I do winder it this could be a bit too sticky and attract grit into the seals ? any better suggestions ?
Posted : 27/02/2017 11:11 am
lbs suggested this to me too when i collected the reign. its only had one muddy ride so far and so far so good...but i did unscrew the collar for inspection and it looked like it needed a bit of a wipe and re-grease. hopefully touch wood that's all it needs but its nice to know that giant are good with their warranties
Posted : 27/02/2017 11:26 am
I bought a Dirt Flap and spray Fork Juice on mine.
Posted : 27/02/2017 11:39 am
Silicone spray from Halfords but it doesn't smell as nice as fork juice.
Posted : 27/02/2017 11:41 am
^^^^ where did you get the Dirt Flap ?
Bentley components, but if you google 'dirt flap' you'll find it.
Honestly, it's not a trick ๐Ÿ™‚
Posted : 27/02/2017 11:42 am
 nach
Slick Honey is recommended by some manufacturers. SRAM do their own. I've shoved chain lube down a dropper in a pinch before. Some lube is better than none, and if guck is getting inside the post that fast you probably have bigger worries than how sticky the lube is.
Posted : 27/02/2017 11:44 am
thegreatape, cheers, found it ๐Ÿ™‚
Posted : 27/02/2017 11:50 am
I do this with my KS every few rides. It does help noticeably, and the seal appears to keep it inside the post. I used a fairly light, clear grease - name escapes me. Slick Honey seems to be the go-to, although I had trouble getting hold of it. Otherwise I Juice Lube it like a fork stanchion too, and run a Mud Hugger rear guard through the winter.
Posted : 27/02/2017 11:56 am
 km79
sandwicheater - Member
I've been using this on forks, shock and dropper for a couple years now. Works great.
Posted : 27/02/2017 12:02 pm
As above been using a small squirt of WD40 silicone spray on forks, shocks and droppers for quite some time with no problems
Posted : 27/02/2017 12:08 pm
Erm Shimano dry chain lube. I use it for the forks as well seems to work OK
Posted : 27/02/2017 12:15 pm
Anyone got a link to the halfords one I can't seem to find it
Posted : 27/02/2017 12:28 pm
cheers all, will look at getting one of those dirt flaps and use in conjunction with the Fork Juice I have
Posted : 27/02/2017 12:29 pm
That dirt flap is ideal... ordered.
I've been using fork juice on my dropper, forks and shock for years, doesn't seem to have caused any issues.
Posted : 27/02/2017 12:33 pm
SRAM butter - available on Amazon, looks worth a punt and a bit thicker than Fork Juice, so will get some of that, cheers
Posted : 27/02/2017 12:37 pm
Here for reference: http://bentleycomponents.co.uk/dirt_20832.html
Though the strip of innertube arranged in a similar fashion and two zip ties has been doing great service on my Giant dropper for 4 years and counting!!
Posted : 27/02/2017 12:39 pm
nach - Member
Apparently SRAM butter is now actually slick honey- my pot's something different but someone told me on here it's changed.
Slick Honey's great stuff but kind of a pain to find at a good price, I bought a big tub off ebay out of frustration but it'll last me years.
Posted : 27/02/2017 12:58 pm
Slick honey, I give mine a little dab round the base of the stanchion post ride then operate a couple of times and wipe the excess off leaving a film on the shaft (ooer).
Posted : 27/02/2017 4:34 pm
 nach
Northwind - Member
Good to know, thanks. I bought a syringe of it a few years back and it's lasting so far, probably because I only use it for droppers and suspension.
Posted : 27/02/2017 4:57 pm
will lithium grease or a marine type grease be ok to use?
ive used lithium grease before on bearings and its lasted really well
currently got some of that muc off bio grease...smells nice but seems abit thin...used it on some hub bearings and it didnt last very well...smells nice though!
alternate option is to buy some proper shimano grease as that seems to last well too
EDIT: just read up on the slick honey...looks like im shopping tonight
Posted : 27/02/2017 6:32 pm
 km79
ogden - Member
http://www.halfords.com/motoring/engine-oils-fluids/grease/halfords-silicone-lubricant-400ml
Posted : 27/02/2017 6:33 pm
Fenwicks, liberally applied before each ride and then cycled through the travel, works for me.
Posted : 27/02/2017 7:09 pm
I couldn't find Slick Honey in a decent size so went for the SRAM butter on Amazon with free delivery. Sounds like it's much the same thing though..
Dirt flap arrived and used the other night. Seems to do a decent job, so will see if that, combined with SRAM butter makes my warranty Giant Dropper last a bit longer !
Posted : 10/03/2017 7:58 am
Finish line stanchion lube for me. One drip on the seal, wait for capillary action to pull it around, cycles component a few times.
Posted : 10/03/2017 8:14 am
The lightest smear of Molykote 33 on dropper post and fork stanchions.
Posted : 10/03/2017 9:09 am
Ghetto innertube dirtflap.
Posted : 10/03/2017 9:21 am
I just use a couple of drops of fork oil, the same with fork stanchions
Posted : 10/03/2017 11:13 am
