Best Combination of...
[Closed] Best Combination of helmet mount and dealextreme torch?
I've currently been using a cree q5 torch with 18650 Li-Ions and cable ties, the torch keeps dicking out so i'm after a new one, and a helmet mount to go with it, any recommendations?
Posted : 18/01/2010 4:08 pm
P7 Torch [url] http://www.dealextreme.com/details.dx/sku.12325 [/url]
Helmet mount [url] http://www.dealextreme.com/details.dx/sku.12000 [/url]
Posted : 18/01/2010 4:22 pm
you know those plastic clips you get with mini pumps? , well if you cut the tabs off and smooth the base then you can bodge it onto your helmet with cable ties. i put a piece of old innertube under to keep everything steady.
the p7 torch snaps in tight as you like ๐Ÿ˜€
or you could buy the one above
Posted : 18/01/2010 5:50 pm
And the SKU12060 is the P7 torch to go for. I've had two dodgy 2-mode ones. The 12060's seem a lot more durable / reliable. Inner-tube & zip ties is the best mounting. I have the rubber mounts but they wobble about a bit.
Posted : 18/01/2010 5:55 pm
