Best chain lube to ...
[Closed] Best chain lube to use?
[#3355076]
Not really sure what's best to use these days.
Does anyone bother with wet or dry chain lubes or should I just use a can of good old WD40?
Posted : 15/11/2011 9:24 pm
Muc Off Wet Lube
Posted : 15/11/2011 9:25 pm
WD40 is not a lubricant but a water displacer. Not suitable for lubricating your chain. I put GT85 in that same category as well.
I currently use Rock and Roll extreme but when the big bottle runs out I may need to find an alternative.
Posted : 15/11/2011 9:33 pm
Finish line wet
Posted : 15/11/2011 9:34 pm
So should I use my WD40 to spray on the chain after washing my bike, then add a chain lube?
Posted : 15/11/2011 9:36 pm
Rock N Roll...Chain lube is great. But read the instructions! Wet the chain with it then wipe it off well with an old rag(old cotton shirts work well!)... I have used Finishline XC etc in the past but this is the best i have found...almost eliminates chain cleaning
Posted : 15/11/2011 9:44 pm
WD40 Will prevent a clean chain from rusting, but will also prevent a proper lube from sticking to the chain.
As far as lubes go, I have tried Purple Extreme, Juice Lube, Finish Line and a few more I can't remember. But the best so far has been Green Oil, it seems to outlast others by quite a margin. Never been left with a dry chain yet, no matter what conditions I had ridden in. 8)
Posted : 15/11/2011 9:46 pm
You could do. I tend to do that if I am in a rush after washing the bike down and not time to sort the chain properly. The WD will get the water out/off the chain. I then clean and lube when I come back to it in the next few days. I tend to wipe as much WD40 off if I am lubing the chain for a ride without fully cleaning it first.
If I have the time then the chain gets cleaned, wiped dry and then lubed ready for nest ride.
Posted : 15/11/2011 9:47 pm
I have just converted to Rock N Roll and it is way better than anything else I have used.
As above follow the instructions and you will be quite amazed.
rock n roll wet (blue one ) is the best one i've used cleans the chain too , got the muc off one as i ran out of r n r , but chain been dirty and claggy since going back to muc off stuff
Posted : 15/11/2011 9:49 pm
Most posts seem to relate to wet lube... Is this better than dry even if you clean and re lube after each ride?
Posted : 15/11/2011 9:52 pm
Yes, particularly in the winter as I find it stays on the chain better. A dry lube gets washed off more quickly. Second what people have mentioned about Rock n Roll extreme lube - excellent stuff in my experience. I use Squirt in the summer and on the road bike but it's no good for winter use.
Posted : 15/11/2011 9:55 pm
I recommend Rock n Roll Extreme for wet rides and Rock n Roll Gold for dry, easy to use and leaves a very clean and quiet chain if you follow the instructions although I apply it in the middle of the chain with a rag underneath rather than on the cassette as I don't want the degreaser getting in the free hub or wheel bearings.
That said has anyone used Muc Off C3 Ceramic wet lube?
Posted : 15/11/2011 10:00 pm
Mark N alluded to it, but, I wouldn't use GT85, WD40, I believe both use petrol based carrier. Fave lube of mine is Finish line wet, Juice lubes (I won some) quite good too.
Posted : 15/11/2011 10:18 pm
I use the rock and roll blue stuff as well. It's ace, frankly.
Posted : 15/11/2011 10:19 pm
Surprisingly the Halfords wet lube appears to be rather good.
Posted : 15/11/2011 10:52 pm
Since I moved to using Rock N Roll Lube.... chain wear has reduced...( I use Park Chain checker)...works in wet and dry
Posted : 15/11/2011 10:56 pm
Putoline chain wax - the performance is so superior to anything else.
I used to use finish line - My chains are now lasting several times as long and I only lube them every few hundred miles
superior to anything else I have tried including purple extreme
Its a solid wax in a tin - you melt it on the stove and dunk the chain. A filthy faff but well worth it. £18 a kilo not a fiver for 50 ml
Posted : 15/11/2011 11:06 pm
So after cleaning bike the chain is all wet, if you leave it it will rust. If you use gt85 it will effect the lube application, so what's the best option? At the moment I go with gt85 then apply lube the next day once gt85 has evaporated.
Posted : 15/11/2011 11:10 pm
Any synthetic engine oil works well use sparinly, and alos the Pound can of spray oil from Poundworld, not Poundland works extremely well , evaporates quickly and leaves a good lube base.
Oh and its only a quid.
Posted : 15/11/2011 11:14 pm
sam 0- use the wax you only need lube the chain every few hundred miles - maybe a coupld of hundred in foul conditions
Posted : 15/11/2011 11:16 pm
I wash my bike where the water drains into my garden so have moved to Green Oil. It works well too!
Got the other products too, but not yet tried them
Posted : 15/11/2011 11:24 pm
I've used Rock n Roll blue all year round for years - nasty shit it is!
Petrol based and eats your skin if you don't wash it off straight away.
Think I might have a go with the waxy stuff when my current vat of it runs out.
Dry the chain & cogs with a towel.
[i]you melt it on the stove and dunk the chain[/i]
Like we used to do with Duckhams, a million years ago TJ?
A stove? I think my Gran had one of those (& I'm 55!)
Seriously though TJ, does much crap stick to the chain? I've been using White Lightning Epic, which in my (ex motorcycle trials & MTB)experience, is pretty good.
Posted : 15/11/2011 11:30 pm
I like Finish Line Epic myself... Works for everything bar horrible clay mud. Their other lubes don't seem that great though, the wet lube is just poor IMO.
Posted : 15/11/2011 11:32 pm
very similar esselgruntfuttock - updated with graphite and stuff
Not much crap sticks to the chain - two reasons - I wipe the outside of the chain down to remove excess and as its a solid wax once any exposed wx gets coated in dust then its no longer sticky.
Posted : 15/11/2011 11:33 pm
Finish Line Wet, dry lubes just aren't worth bothering with in the this country IMO.
I can't really be bothered with trying loads of different ones although there might well be some better ones than Finish Line out there- I think it would be quite hard to really tell the difference unless they were spectacularly much better or worse, and I doubt any of them are.
Posted : 15/11/2011 11:47 pm
Anyone know if finish line wet from a bottle is hte same as the aerosol? It seems thicker out of the aerosol once the carrier's flashed off.
Posted : 15/11/2011 11:48 pm
Mr salmon - I get much much longer chainlife now and the lube is much cheaper.
any of the edinbburgh folk want to try it email me - I'll do a chain for you
Posted : 15/11/2011 11:50 pm
thats so it sticks to your rotors , when you spray it on , i'd stick to bottled stuff
Posted : 16/11/2011 12:01 am
TJ - That's too good an offer to refuse. email on it's way!
Posted : 16/11/2011 12:09 am
Rock n Roll Extreme here as well, SO much better than everything else available.
Rob Hilton - Member
In that it's based around Light Hydrocarbon solvents NOT Petrol!
Posted : 16/11/2011 12:12 am
shieldsmtb - Member
I lube my chains off the bike... Just, I seem to get better results from the aerosol stuff, but maybe it's just down to application.
Posted : 16/11/2011 12:13 am
 7hz
sam_underhill - Member
Not if you don't use washing up liquid to clean the bike, and take the bike inside to dry off afterwards - find the bike dries in a couple of hours inside.
Posted : 16/11/2011 1:26 am
I use 50/50 Sardine Oil and Double Cream - gently warmed.
For some reason I run over a lot of cats.
Posted : 16/11/2011 2:17 pm
My mistake! Dunno what light hydrocarbons are but it's sure good for getting a fire started. 😉
Edit: From Wikepaedo
The catalyst-free hydrocarbons are routed to a main fractionator for separation into fuel gas, LPG, gasoline, naphtha, light cycle oils used in diesel and jet fuel, and heavy fuel oil.
I'm happy with my layman's term description :mrgreen:
Posted : 16/11/2011 2:35 pm
Rock n Roll Extreme for LOTS of reasons
Its the shizzle bizzle wotzzit
Posted : 16/11/2011 3:07 pm
couldashouldawoulda - Member
Well I did his chain with the wax today - anyone else want to try it?
Posted : 16/11/2011 3:08 pm
GT-85 is almost perfect. Spray that shit everywhere but remove brake pads and rotors. Its an awesome degreaser and its only 2.50 a pop at halfords.
You can use it on your chain but you must ensure to wipe your chain down after each ride and reapply. It will work fine - but if you forget to apply now and again then your chain will develop rust.
Dont bother white spiriting the chain and all that bollocks. Been there done that. Works better than just about anything if done correctly. Nasty for the environment though. Just wipe down for a couple of minutes and lob the chain into a tub of oil for a few hours. Hang the chain up above the container with a coffee filter, add infinitum. And you are done.
Posted : 12/08/2012 11:34 pm
anyone got a linky for the rock n roll one?
Posted : 12/08/2012 11:47 pm
Back on squirt lube now til winter.
Posted : 13/08/2012 12:35 am
after ride, clean chain using swarfega patio cleaner! spray on, rinse off, and wipe dry
i then spray 3-in-1 PTFE Spray Oil ( big tin £4) on chain, and wipe a bit, the day before a ride, it sort of drys out
and repeat! takes 5 min end of every ride
Posted : 13/08/2012 7:41 am
gt85 or wd 40 will work fine BUT need to have a clean drive train, or it will just wear it out
Posted : 13/08/2012 7:42 am
I ordered some bits and bobs from bike discount a while back and picked up some of [url= http://www.bike-discount.de/shop/k983/a2048/chain-lubricant-100-ml.html ]this[/url].
I'm really impressed - although thin, its cheap, lasts ages, great in the mud, and makes the chain dead easy to clean when you need to. Better IMO than finish line / muc-off / fenwicks.
[edit]
if you look further down you can get some 'Suspension fork deodorant' 😯
Posted : 13/08/2012 3:03 pm
Be wary of Rock & Roll or anything similar if you have an MRP chain guide.
That wee orange leaflet they put in the packaging warning off solvent based lubes - they do mena it.
Posted : 13/08/2012 3:13 pm
