Best 10spd shifter ...
[Closed] Best 10spd shifter / mech combo for a wide range cassette
Hi,
I've got an 11-42t cassette on the rear and I'm struggling to get my SRAM X9 10spd derailleur to work properly with it - at the moment it won't shift onto the largest sprocket. I've done the whole b screw thing.
I think the problem is actually that the mech is a bit jiggered from various knocks it's had +/- wear from 2 years of use. I'm thinking of buying a new mech +/- a new shifter. Any advice about what would be the best combo for a wide range cassette?
Ta
Posted : 14/08/2016 10:11 am
Is this a SRAM 11 speed block or some sort of home made thing?
Posted : 14/08/2016 12:13 pm
10 speed.. Saint shifter and zee mech ftw
Posted : 14/08/2016 12:27 pm
SRAM mechanic at 'Ard Rock gave me a bit of a lecture about the problems with using a GX rear mech with any kind of expanded 10 speed cassette (I run 11-40). Then sold me an X9 to replace it...
Posted : 14/08/2016 12:54 pm
I was recently surprised how well a zee mech worked on a sunrace 11-42 cassette.
Posted : 14/08/2016 2:11 pm
Zee mech... they only seem to be available in short cage versions. I was under the impression (perhaps wrongly) that you need a long cage for wide ratios / bigger sprockets. Am I wrong about that (too)?
Posted : 14/08/2016 2:48 pm
There are two versions, the DH and the FR. The FR is only supposed to be good up to 36t cassette but it was all I had spare so I tried it and it works really well.,
Posted : 14/08/2016 9:31 pm
Having run x9 10sp on 11-40, seen mates do it fine 11-42 what was the problem, by done the whole B tension screw did you replace it with the longer one?
I had an XT but it needed the RAD Cage to make it get even close to working on 42t.
GX 11sp for the win these days ๐Ÿ˜‰
Posted : 15/08/2016 1:10 am
Saint shifter, zee mech with Radr cage. best quality shifting I've had. Bombproof too.
On 11spd xt with XTR shifter now.
Posted : 15/08/2016 1:25 am
I've currently got an X9 on one bike with a 11-40 10 speed set up and shifting is great.
Posted : 15/08/2016 5:18 am
XT with RAD cage and a Saint shifter is a great combo.
Posted : 15/08/2016 6:34 am
Another vote for the Saint + wide range Zee combo
Posted : 15/08/2016 8:00 am
XTR shifter, Saint mech with RadR cage works flawlessly here on Sunrace MX3 11-42
Always go for the best shifter you can, will make more difference that a posher mech IMO.
Posted : 15/08/2016 8:03 am
