bedding in pads - i...
[Closed] bedding in pads - is this bollox?
http://twitter.com/twinklydave
Posted : 04/01/2012 10:20 pm
bump
Posted : 05/01/2012 7:31 am
Nope, bedding in pads in common practice. I've seen Shimano pads last only 2 hours of riding (changed in the car park before the ride) in the Peaks when not bedded in compared to several months when correctly cured.
Why do you think Automotive brake pads require several short sharp stops before they perform correctly? The heat and pressure applied to the pad, forces material from the pad on to the disc and also removes any surface compounds from the pad. Finally the heat and pressure applied during those first hard stops, compacts the pad material making it slightly more dense and less prone to surface abrasion while maintaining a high friction co-efficient.
D.
Posted : 05/01/2012 8:28 am
Its more of an issue with organic pads. Bedding in does 3 things - it cures the pad under heat and pressure, it conforms the pad to the disc and it deposits a microscopic layer of pad material on the disc.
This allows adherent friction to occur which is when you get a semimolten boundary layer that in effect sheers. thus you get long pad life. If you do not have this boundary layer you get abrasive friction and short pad life.
On the tandem the brakes get very hot indeed and are used a lot - and pads last thousands of miles not matter the conditions.
So brakes, riding styles, pads will bed in easily in normal riding, some rtequire the deliberate bedding in. You can tell the change in feel as they bed in. At the puffer I bedded in anew set of pads simply by dragging them down the main descent
Posted : 05/01/2012 8:54 am
daffy read the question before spouting - its about a METHOD of bedding in not whether or not TOO bed in!!
Posted : 05/01/2012 9:25 am
 devs
Blowtorch and oven are indeed bollox. It's all about material transfer between pad and rotor under heat and pressure. IMHO of course before I get accused of being all TJ.
Posted : 05/01/2012 9:43 am
It's also about those pads on that disc. A new, properly cleaned rotor just ridden from the box wont feel as good as the original one, unless pads are changed and bedded.
Posted : 05/01/2012 9:47 am
The blowtorch and oven will only do a part of the bedding in process as above - however if you are using the same pads the layer on the disc will still be there - he also makes a good point about dragging one brake rather than using two intermittantly
best tip tho - use hopes as they appear to have much longer pad life. i used less than a set of pads (a half worn set wore out and the replacements less than half worn) in 9 laps
Posted : 05/01/2012 9:50 am
as above - I just do 20 or so hard braking stops and ride dragging the brake slightly to build up some heat. been told to give them a quick soak with cold water after too, but didnt seem to make any difference
Posted : 05/01/2012 9:58 am
cold water - superstar by anychance? will do nothing to bedding in.
Posted : 05/01/2012 9:59 am
I thought the cold water thing on the superstar recommendation was so that you knew you'd achieved a decent temperature, not part of the bedding in process per se?
Posted : 05/01/2012 10:02 am
Maybe if you actually phrased your OP unambigously rather than lazily pasting in a URL, you'd have got the response you were looking for, rather than the response you got. ๐Ÿ™„
Posted : 05/01/2012 10:09 am
I can't see the tip about using your turbo trainer & fitting the pads in the rear caliper to bed them in being much good.
You are only stopping the back wheel from rotating, there is barely any momentum there compared to doing 15mph down the road & coming to a quick stop.
I often struggle to get heat into the back pads even when bedding in on the road & doing repeated stops. I have to do more hard stops on the rear compared to the front.
Posted : 05/01/2012 10:24 am
Nope, always bed in my pads (where possible) however when i haven't when they have been changed during 10under for example they didn't last, coincidence?
Posted : 05/01/2012 10:27 am
If you keep pedaling thats ~400watt, gets it pretty hot, especialy with a small rotor.
Posted : 05/01/2012 10:37 am
keep trotting out the dogma ๐Ÿ™„
Posted : 05/01/2012 10:43 am
thomthumb - [i]appear to[/i]
I have been following this rapid pad wear issue for a long time and collecting information. while its clearly complex and multifactorial hope brakes do seem to have much longer pad life in general. Somone commented on this in the last couple of days.
Posted : 05/01/2012 10:46 am
 Pyro
At the Kielder 100 this year, there was a bit of a consensus that the Clarks pads were the ones lasting best. This was, presumably, un-bedded, straight replacements.
Posted : 05/01/2012 11:25 am
Never bedded any in and never had any trouble.
Posted : 05/01/2012 11:28 am
Drac - you will be bedding them in or the pad will go in a short time - its just that your set up, type of riding, riding style means they bed in in normal use
Posted : 05/01/2012 11:30 am
I'm wholely for bedding and believe it's required... however...in relation to the story, I'm not so sure about bedding of metallic sintered pads "by oven". By definition the sintering process has taken the brake friction material to a pressure and temperature that the metal has begun to melt and fuse throughout its volume. Your oven can't do this and the pretty rainbow coloured change is simply oxidation due to the fact that you're re-heating them in air (they'll have been sintered in an inert atmosphere).
Either way, bedding is required to do the material transfer and surface conformation process, but the only good an oven is for, IMO, is burning off contaminants and saving otherwise trashed pads. I've run brakes without bedding them in and sometimes got away with it, sometimes (particularly in scottish mud) I've lost a set of pads in a couple of wet miserable rides.
Posted : 05/01/2012 11:40 am
you aint melting the metal, your trying to melt the resin in which the metal is embedded. the mp. is 200C(ish), most ovens can do this. otherwise the entire mcains empire would be ruined.
Posted : 05/01/2012 11:48 am
Who was it that TJ used to have the big rows with about bedding in pads?
I'm in the 'bedding in' camp by the way. A few hard stops to do so.
Posted : 05/01/2012 11:55 am
I've never 'bedded' pads in. Slap them in and just ride with them. Always worked for me and have lasted fine.
Posted : 05/01/2012 12:00 pm
I agree with TJ on this.
My hopes always outlast the pads in my shimano (OK) and avid (the worst) brakes, the power goes the opposite way though. with the avids outperforming the shimano and hope.
Small rotors = more heat = longer life, and theres no need for 8" disks in mud anyway.
I usualy take loadsa spares on holliday and run new pads each day, big hills + sunshine = hot brakes and pads that last for months.
Posted : 05/01/2012 12:01 pm
Really? You change pads each day? Done two weeks in Canada and never changed pads. Only changed a set in the Alps once as the first set were older anyhow.
Posted : 05/01/2012 12:03 pm
coffeeking - Member
Genuine question... if the bedding in isn't about getting heat into the pads, but is about getting some pad material on the discs, why wasn't there a transfer at the start of your wet miserable rides?
Posted : 05/01/2012 12:07 pm
The pad material on rotor argument falls down the moment you get some mud on the rotor or caliper, as its essentially like using valve grinding paste and will remove anything that has built up on the rotor.
Posted : 05/01/2012 1:14 pm
I think it depends on the pads. Hope pads don't seem to need to specific bedding in (though i find throwing some sandy mud at them helps - also a good cure for slight contamination with brake fluid). Magura have some very specific bed in instructions.
My attempts to save pads that had got fluid on them in the oven/blowtorch/setting fire to them always resulted in me completely destroying the pads or having no effect.
Posted : 05/01/2012 1:30 pm
I put new sintered pads in ride up and down my street full tilt and brake with the front until I can endo then brake with the back until it locks up easily. I suppose that's bedding in and then they seem to last for months. In the Alps this year I changed a set of fronts for Kevlars at the top of the lift and they had gone by the bottom of the first descent (20 minutes or so) so I won't be using them again.
Posted : 05/01/2012 1:33 pm
coogan - Member
Read the post, I just do that to bed them in, I've never worn pads apreciably in Spain, forgot spares the first time and came back with the same ~1mm of pad I went out with. Had problems glazing them though.
Posted : 05/01/2012 1:54 pm
no it was another chap i ride with from time to time, no idea where he got that jewel from
Posted : 05/01/2012 1:57 pm
It is about heat as well
bigjim - Member
One turn of the wheel and the disc is clean - a part of the reason for the drillings in it. Its only with the layer of pad material on the disc you get adherent friction. if you don't have it you get abrasive friction and rapid wear. Its a very hard and thin layer
My theory for the very fast wear that some folk get in some conditions is that the layer on the disc is abraded away faster than it can be replenished thus leading to abrasive friction and rapid wear
Posted : 05/01/2012 2:15 pm
 devs
In crude terms. Rotor = cheese grater. Pad = cheese. Melt cheese over surface of crater and hey presto no gratey, just grippy. Don't melt cheese over grater and cheese get grated away. Ken.
If your disks are too big for you = no heat = pad wear.
If it's really wet and miserable and you don't find a hill big enough to clean and heat brakes = pad wear. In bad cases you seem to wear pads without even braking, just with the paste rubbing against them. Simples.
Hopes are betterer because there is more surface in teh first place. Nae great science rocketry.
Posted : 05/01/2012 2:41 pm
As an engineer involved in braking (aerospace and rail), I've spent a fair amount of time with friction materials, testing them and developing them.
Bedding in is definitely required to condition the surfaces and the heat forces out any moisture which may have become entrained within the material. As has been stated above, it's all about setting up a stable interface layer, once it's established, there is very little abrasive wear.
We spend a long time explaining to aircraft operators that a series of low speed taxi stops cause far more wear than a landing which gets the brake up to temperature quickly, thats probably more specific to carbon brakes though!
Posted : 05/01/2012 2:47 pm
I like the cheese analogy, clear as cheddar now.
*skulks off to re-place smaller brake discs and bed new pads all fitted yesterday*
Posted : 05/01/2012 3:14 pm
Coogan, I think he's saying that he uses the alps riding to bed lots of sets of pads in for the rest of the year...
Posted : 05/01/2012 3:21 pm
For something like the puffer, I'd suggest getting a number of sets of spare pads (all same make as ones in the brake already if poss) and go through the bedding in process with each set before you need to use them in anger.
That way you should be using similar compounds on the discs, you're also bedding them in and hardening them up. Then put them back in the packets until you need them.
Not ideal and a bit of a PITA, but it means they should last a lot longer.
Posted : 05/01/2012 3:27 pm
fwiw ive never (consciously) bedded in a set of pads and yet they seem to last ages
(i use standard hope pads on both dh and xc bikes)
Posted : 05/01/2012 3:31 pm
And so the whole thread goes full circle, wearing out its pads as it goes... TJ, come and ride your bedded-in resin pads in the Peak for a few hours on a sopping wet winter's day and then see how your melted cheese looks ๐Ÿ˜‰
ps: I think anyone who rides with pads made from cheese deserves everything they get. That's just fantasy surely. Even the hardest cheese isn't going to be as durable as even resin pads. Dangerous advice imho.
Posted : 05/01/2012 3:32 pm
BWD - done it with no wear thank you but sintered pads- and other places where people get excessive wear. 9laps at the puffer less than one set of pads, others were going thru a set every 2 laps.
Its a whole multifactorial conundrum - two people can use the same pads in the same conditions and get vastly different wear rates.
Posted : 05/01/2012 3:47 pm
oooh, my name's mentioned
yay me
I've been bedding in pads on the turbo trainer by pedaling with the rear brake dragging - occasionally splashing a bit of water on the disc to make sure it's getting nice and hot.
It's not as good as 'proper' bedding in, outside, down a big hill, but is preferable to getting blown away by the wind when I don't need to!
"I find" bedded in pads last longer than ones taken straight from the packet. Your experience may be of no interest to me ๐Ÿ˜›
Posted : 05/01/2012 4:02 pm
Didn't Mark Datz offer some good advice on bedding in pads a year or two ago?
๐Ÿ˜›
Posted : 05/01/2012 4:12 pm
BWD, im not sure why you've quoted me?
My point was that it needed doing in advance of the puffer and it needing doing on the bike. Heat on its own wont do it.
Posted : 05/01/2012 4:30 pm
Bigyinn, I quoted you because in fact that's pretty much what Mike Hall says. I think people are misunderstanding the heat treating thing, it's not intended as a substitute for bedding in, but an additional thing.
TJ, I'm not even going to begin discussing anything with you. There's a perfectly good brick wall out there if I want to beat my head against something, thanks.
Posted : 05/01/2012 4:52 pm
lol @ BWD. Dont do that, you may dislodge some mortar.
Sadly TJ only knows Hopes, therefore everyone else must be using the wrong brakes or doing it wrong. The only way to silence him would be to [s]fit his tandem with an alternative make of disc brake and let him run it for a year[/s] beat him to death with a black rubber dildo (12" pref).
Posted : 05/01/2012 5:53 pm
I have used other brakes. I have also been following the debate on pad wear for a long time. Some folk me included can ride in areas where the short pad life is common but still not get the short life.
Posted : 05/01/2012 6:12 pm
 GW
never understood anyone wearing out a set of disc pads in less than a year, never mind one lap of an XC course with any make of brake.
If I ever got anywhere close to that sort of wear I'd be switching back to V-brakes pronto.
Posted : 05/01/2012 6:55 pm
So you can wear out your rims in a year instead? No thanks, I'd rather replace pads and or discs than rims anytime!
Posted : 05/01/2012 7:00 pm
 GEDA
Are brake pads not made by pressing the brake material at high pressures onto the backing plate while at high temperatures?
Posted : 05/01/2012 7:14 pm
TandemJeremy - Member
Can you post your data so we can all analyse it?
Posted : 05/01/2012 7:19 pm
captjon - unfortunately its scattered around and mainly in my head so not of a great deal of use apart from for my interest
Lots of threads on here about it and lots of folks experiences on there Scienceofficer did some good analysis as well
Posted : 05/01/2012 7:22 pm
 GEDA
The biggest factor in pad life is a. how much you brake and if you are not braking then if your pads are rubbing or not.
So we're stuck with your assertions based on your memory of posters self reporting..? How do you account for the myriad factors which affect pad wear and the variability between riders? And what about confounding variables?
Posted : 05/01/2012 7:47 pm
Capt - plus the reading I have done and the discussions with the manufactures of brakes. Are yo really interested in what I have found =or are you looking to slag me off? Its unfortunate I have not collated the info well. The only thing I can be really sure of is that its a multi factorial conundrum when two riders using the same equipent doing the same rides in the same weather get dramatically different pad wear rates
If you are really interested I will spend some time typing out what I have found
Geda - the crucial thing I believe is the the formation of the boundary boundary layer and getting adherent friction - which requires heat in the pads. I brake a lot on the tandem and pads last thousands of miles - because they get very hot indeed even when ridden for multiple miles full of abrasive grit
Posted : 05/01/2012 7:56 pm
I'm interested in how you came to your conclusion because i hate it when people declare things but don't back up their claims with evidence. It is even worse when they say they have data but can't/won't share it, or don't explain their methodology. I think multifactorial is one word btw.
Posted : 05/01/2012 8:00 pm
Sorry - my spellchecker splits multifactorial ๐Ÿ™‚ its a real shame I have not kept all the data so all I really have is whats in my memory and the various threads on here. I did not realise it would get so complex and interesting
I am about to have dinner - I will write up what I have found out and post it later on ad I'll find as many sources as I can
Posted : 05/01/2012 8:10 pm
good stuff
Posted : 05/01/2012 8:24 pm
Ok - capt asked me to put down what I had found out . as above I have not kept most of the source material as I did not realise it would get so complex or interesting. I do not mean to be patronising but am trying to make this complete. I have looked at the wear that many different riders get and tryed to gain some understanding of how they ride
[b]basics of how they work. [/b]
There are two types of friction generated between the pad and disc - abrasive and adherent friction. Abrasive is what we all know - like dragging your hand across sandpaper. Adherent is a little different as it only occurs when there is a microscopically thin layer of pad material on the disc and you get chemical bonds created and broken in a semi fluid boundary layer. as an analogy think about a layer of treacle between the sandpaper and your hand - still resistant to movement but its differnt and you don't wear the skin off your hand.
Abrasive friction occurs more at low temps, adherent at high temps. Abrasive friction creates more pad wear. Abrasive friction is more with sintered pads and less with organic - sintered pads are much harder hence even tho they have more abrasive friction they last longer.
disc brakes have a temperature range under which they work effectively and at the interface this will be hundreds of degrees C
[b]Bedding in.[/b]
does 3 things - cures the pad under pressure and heat, puts thin layer of molten pad material on the disc and conforms the pad to the disc.
[url= http://www.stoptech.com/technical-support/technical-white-papers/bed-in-theory-definitions-and-procedures/brake-pad-bed-in ]all this stuff is known and accepted in the automotive world. [/url] ?Some folk and brakes will need deliberate bedding in, some will bed in in normal usage. the key is you need to get them very hot
[b]Now why do we get the rapid pad wear under some circumstances?
[/b]
From what I have read and pondered it is when for whatever reason the deposit on the disc gets removed faster than it can be recreated and the brake system goes into abrasive not adherent friction which simply wears the pads away. But why does this happen?
If the brake is being used in an abrasive environment the disc transfer layer will get worn off - however if the brake is hot it will get redeposited quickly enough ( its only a few molecules thick) to keep the brake in adherent friction. However if its cold and wet and the brake is not getting hot then it will not be redeposited at all or enough, the brake goes into abrasive friction and the pad wears out.
The braking surface will be completely clear of grit after one revolution of the wheel or less - its not the grit that wears the pad - its the lack of the disc transfer layer that wears the pad if the grit has removed the boundary layer.
some folk say the pad gets worn simply by the gritty disc running thru it with the brake not on - we have all heard the noise that makes. I believe the pad is too hard for this to create any significant wear
Dragging the brakes creates heat so should not cause excessive wear but a very light touch on the brake may allow grit to get between the pad and the disc and create wear by removing the transfer layer
[b]
Factors affecting the wear rates[/b]
Its obviously multifactorial and its when a number of conditions stack up against you that the rapid wear starts
this is where the conundrum starts 'cos every time I think I have found a crucial factor someone comes along with experience that does not fit the theory.
Different pad materials and set ups have different working heat ranges - and it may be that some are better at running cooler than others
different disc drilling patterns may be better at clearing grit off the disc.
different manufactures pads will also be different composition and hardness.
Obviously diffent soil / gravel conditions are a factor but cannot be the only one for even in the areas such as afan and peaks where people get the rapid wear others do not.
Different riding styles clearly play a huge part as people with identical equipment in identical conditions some get the rapid wear some do not. However its not as simple as quick riders don't get the wear or slow riders who brake a lot dont get the wear. I am fairly slow and tend to drag the brakes a lot - but don't get rapid wear even in conditions where others do. Jambo is a quick rider and he does not get the rapid wear even tho he rides in areas where others get rapid wear
I believe a part of it is the number of times you apply the brake on each descent as each time you apply the brake ( when the brake is wet and gritty) for the first turn the transfer layer is getting worn away. I am dragging the brakes the whole way so generating a lot of heat and only one opportunity to remove the transfer layer. Jambo is only using the brakes twice the whole descent and each time he uses them hard - so little opportunity to wear the transfer layer and each time heat generated to replenish it. If you are on and off the brakes the whole descent but only using the brakes gently you are having a lot of opportunities to wear the transfer layer but are not generating enough heat to replenish it.
On the tandem the brakes get used hard the whole time and pad life is many thousands of miles
Smaller discs get hotter more easily so smaller discs should reduce the wear as they get hotter and the transfer layer is replenished more easily. certainly I run 160s only my solo and get long life.
I literally get many thousands of miles of life from my pads and all my discs are discoloured fro the heat. The front on my solo which probably gets the least heat in it wears quickest.
However some people still get short pad life in the alps where brakes get hot indeed. It may be possible that the rapid wear in the alps as well as reflecting a years use in a day is also down to the pads overheating and partly melting or going out of their heat range
[b]conclusion[/b]
its complex and multifactorial. I believe the transfer layer is the key and this needs heat to generate it so it when the transfer layer gets worn away and not replenished quickly enough the rapid wear occurs. If the pad has never got hot it will wear as it will remain soft.
You need to keep the pad in its working temperature range and this varies from manufacturer to manufacturer. some generate heat more easily than others and some requite higher temps to create the transfer layer.
If you are getting the rapid wear try sintered pads obviously. try smaller discs if you have big ones, try dragging one brake rather than using two intermittently, try using the brakes in short hard bursts not gently.
IU shall try to keep note of teh info I collect on this in the future and I am very intersted in peoples experiences to see if they fit the pattern
there is also the issues of high temp glazing and low temp polishing of pads as well. It when this has happens abrading the pads with mud improves performance I beleve but that is a whole other issue.
Links to the other discussion on here
http://singletrackworld.com/forum/topic/natural-gift-for-glazing-pads
http://singletrackworld.com/forum/topic/why-do-my-brakes-keep-going-funny
Posted : 05/01/2012 9:55 pm
Thanks for taking the time to write that out TJ. But that doesn't explain your assertion that hope brakes give better pad life.
Posted : 05/01/2012 10:13 pm
I presume that's probably based on experience, testing and observation of others. I know a lot of people who claim to get better life from Hopes than other makes, which will depend on their pad materials and pad sizes. Whether it's true or not, who knows, but lots of peoples experience seems to fit it, some people's doesn't <shrugs>. It's not really important anyway, as it was a side comment to the point of the thread, which has been roundly answered and very well by TJ.
Posted : 05/01/2012 10:20 pm
Right - thats simply from my experience and from what I remember of others experienes - and its a tendenccy not an absolute. No decent data as I have not saved it ๐Ÿ™ TINAS has the same experience on this thread
I believe it may be to do with heat again. Hopes build up a lot of heat easily and / or have a lower working heat range which is why they have a reputation for overheating in the alps but why they dont get the rapid pad wear as often when its cold wet and gritty.
It may also be pad compound? they presumably got tested in UK conditions including winter use whereas in many other countries people don't use bikes in the cold and wet. could be drilling patterns as well?
Posted : 05/01/2012 10:22 pm
A lot of that long post is my theories not hard data but it developed over time looking at what is known and matching it with peoples experience - I want to be a real anorak and get some temp readings from a load of discs sometime
Posted : 05/01/2012 10:25 pm
 devs
I've ridden on a shitty day in the peak and lived! Further more, my pads lasted that day, another day, and then several months of riding in other gritty areas. My pads lasted 5 laps in the puffer last year. Their replacements lasted 6 and then several months of riding in other gritty areas. I use superstar haloumi pads, I find their feta ones are not as long lasting. Hmmmm haloumi and octopus, I can feel some carb loading coming on.
Posted : 05/01/2012 10:29 pm
Pretty sure Hope heat-treat their pads before sale btw (an old magazine feature showed loads of pads going into a kiln), which won't make them last longer than a properly bedded in pad, but will probably make them last a bit better than an untreated, unbedded pad.
Less certain of this, but comparing X2s with OEM pads and with EBC pads, I suspect the OEM ones are a pretty hard compound, they seemed down on power compared to the EBCs and had less initial bite. But o'course there's a lot of other things that could have caused that, so that's mostly supposition.
Posted : 05/01/2012 10:33 pm
Devs another one who does notwear out brakes!
Info would be nice ta
- what brakes?
Riding style? fast / slow? Brake dragger or hard use or light use?
Posted : 05/01/2012 10:56 pm
I don't bother bedding pads in. I typically get through two or three sets of superstar/clarks pads per year. Rich has had the same sets of Avid pads on his bike for 3 years!
I've experienced very rapid pad wear, e.g. a set every two hours, on rainy, splashy days at trail centres when the brakes are constantly being splashed with water and grit. The other time was an enduro near Andover which was sopping wet XC riding on flinty trails.
So the abrasive v.s. adhesive friction argument works for me.
Posted : 05/01/2012 11:13 pm
 devs
I always bed them in. The peak and puffer brakes were Hope 4 mono on 203 and 180 rotors but I also use hFX9, Louise and Formula K24s. I think I am a brake dragger but I'm also heavy at 17st so I think it's the heat thing again.
Posted : 05/01/2012 11:29 pm
Ta chaps
Posted : 05/01/2012 11:51 pm
That'll be the sintered ones, it the standard way they're made, hence my thinking sintered pads don't require the heat element of bedding suggested in the article in the OP.
Posted : 06/01/2012 12:28 am
- what brakes?
Good, more systematic.
My pads last ages. The pads in my Magura Louises have lasted over a year even with regular riding. I bedded them in, weight 12st, not sure of my braking style, but i'm not one of the faster riders i know.
Posted : 06/01/2012 10:07 am
When I lived in sheffield I used hope C2's, some hayes 9's then shimano XTR's. Being a uni student I'd not ridden in the peaks in summer untill this years summertime pootle! Couldn't say which brake lasted longer as I didnt have them all at the same time.
But the key to getting any life at all from them was to drag the brake all the way from Crookes high street, to the arts tower, basicly every ride started with the brakes getting so hot the levers well and trully pumped up and the pad backing discoloured making a cool pattern showing the airflow arround the piston!
Posted : 06/01/2012 10:21 am
Hope 180/160 calipers, SS red pads, no deliberate "bedding in" just normal hard and late braking.
Type of riding, everything from daily tow path/bridleway commute to singletrack - local conditions are loamy soil with some sandy bits.
I try to brake as lttle and as late as possible and don't drag.
Roughly 500 miles a month, pads changed about once a year and even then there's some left......
Posted : 06/01/2012 10:31 am
Any more want to share their tales of brake life / riding style etc?
Posted : 07/01/2012 11:40 am
 GW
What you trying to prove TJ?
I personally think anyone who gets through brake pads at an alarming rate simply either brakes far too much or uses their brakes badly.
currently I have 203, 185 and 160 discs as appropriate for the particular bike in question. brakes are currently Juicys (all sintered)and SLX(organic/resin?). I've only* used sintered pads for well over 10 years (prob closer to 15).
some of the brakes I've lots of experience using are BB7s, Juicys, Hayes, Hopes, Shimano.. there are many many more I've used but it doesn't really matter what brake I have I don't ever go through pads quickly!
Oh.. and I never bed pads in! preferring to just use brakes when they're actually required instead
*the new(ish) SLX I have on my hardtail I believe came with organic/resin (and funnily enough feel underwhelming) but even with those shitty pads after 9mths there are no real signs of wear
to the dick that suggested I'd need new rims every year with V-brakes Don't make me laugh. ๐Ÿ˜†
Posted : 07/01/2012 3:48 pm
Not try to prove anything in particular - trying to get to the reason why some folk get rapid pad wear 'cos its an interesting conundrum as its not as simple as braking more - more wear
Posted : 07/01/2012 6:40 pm
 jimw
I have Hope mono mini's on my Orange 5 - I weigh 90Kg with 183mm disks each end and original Hope organic pads. I had a half worn set when I started a four day trip to the Alps last summer which finished with the Passeporte de soleil. I had no issues with the brakes at all, no overheating, no fade I could discern and at the end I couldn't see any appreciable extra wear. Others on the same trip with Hope M4's seemed to have had some fade at times and have had more wear. Admittedly they were faster than me but I was probably on the brakes longer than them. Could this be that the mini's were running hotter?
I have experienced brake fade with the M960 XTR brakes on my Litespeed locally on the Malverns so I don't think it is technique?
Edit: I always have tried to bed the brakes in every time I change them
Posted : 07/01/2012 6:56 pm
running Avid X0 brakes on my bike, with sintered pads
on New Year's day, went and rode for 6 hours on Pitch Hill, Surrey in foul conditions including deep mud and rain storm, lots of slithery braking action but not heat build up to speak of?
lost 3/4 of the material on very new, but bedded-in disc brake pads
(brakes bedded in by doing 30 emergency stops down a steep hill off Highgate, London) and 2 XC rides in NW london on relatively flat ground in dry conditions
Hope disc brake pads are somewhat different to other "manufacturers" in that Hope make the backing plates in-house, and then ship the backing plates to automotive manufacturer EBC who apply the material to the backing plates and then heat treat them
do other cycle brake pad manufacturers bother with this?
Posted : 07/01/2012 10:12 pm
GW - Member
This is the dick that suggested that, because I used to, smart arse! Ever considered a career in diplomacy GW?
Posted : 08/01/2012 5:25 pm
