What is this all about?
How should I do it and what difference will it make?
the worms are out!
for sintered & organic you can get away without paying too much attention to them, but if your running resin pads (most magura, some shimano) you won't get 100miles out of them if you don't!
Basically find a nice steep hill, ride up it drag A brake the whole way on each run, get it hot! then drench it with water (squirty bottle) whilst braking on it until a standstill. ride back up hill, repeat 2-4times PER BRAKE. job done ๐
I'll stick to sintered and ignore it, sounds like a lot of faff.
Organic/Resin; Same thing
just ride it with the understanding the brake will be crap for a while.
If not bedded in properly and some cack gets in there resin pads will just be eaten to bits in 1 decent ride.
Sintered are better IME.
yep i,ll go along with that ! a few weeks back i put rear organic pads in (big mistake) and quickley bought some sintered pads another week later.... sintered is the way to go !!!
Mecanic in bike shop sed 2 go down big hill slow so breaks get very hot then jump off and turn bike over and spin the wheels and pee on the rotar so they cool down and the niterogin in the pee makes the rotar get harder it's esiar to pee in a bottel and use that
Did the mechanic give you a special deal on a left-handed spanner to?
+1. Should be 100% after the first decent descent
๐ฏ that advice is as wrong as the spelling and grammar
Crikey, that explains why I got through three sets of organic pads in a month this winter. Back onto sintered now, thankfully.
Some folk have a riding style and a brake setup that beds in with normal use, some need to make a deliberate effort.
Bedding in is 3 things, conforming the pad to the disc, curing it under heat and pressure and smearing a microscopically thin layer of pad material on the disc. The second of these is less with sintered pads.
A series of hard stops from speed is what is needed - the pads need to get to hundreds of degrees C. Do not put water on the pad / disc. All it does is cause thermal shock
Well I'm gonna beleve what a mecanic in a shop seys not some randum dude
i fitted some mixed sintered/organic (pads have both materials) ashima pads....
best of both worlds
"Well I'm gonna beleve what a mecanic in a shop seys not some randum dude"
what makes you think he knows any better than TJ ? Seriously .
I think we agree to diasagree
