Bearings - codes an...
[Closed] Bearings - codes and ordering
Need new bearings for my easton wheels, codes are 6902 and 6804 for drive / non-driveside.
Looking on t'interweb must codes have a suffix of some sort. simply bearings .co.uk have rubber shielded deep grove 2rs1.
are these codes important? i presume the first 4 digits dictates the size and the suffix is the sealing / quality?
anyone used simply bearings? any good?
Posted : 06/05/2009 2:11 pm
I have used them just recently and found the service to be great. Your right that the number reffers to the size and type of bearing where as the aditonal number/letters indicate the sheilding type ie 2 rs is 2 rubber sheilds (one either side)
Posted : 06/05/2009 2:15 pm
This may help
http://www.abtbearing.com/dg_partno.html
Posted : 06/05/2009 2:18 pm
thanks, that links handy.
so, for 3 x 6804 and 1 x 6902 skf bearings, which will do my front and rear easton wheels, it comes to 66 quid.
i dont mind paying that if its gonna be longer lasting than the (quite frankly rubbish) easton bearings that it came with, but it does seem a lot. does that price seem normal and what kind of life should i expect from them?
Posted : 06/05/2009 2:30 pm
bearings ain't cheap, I get mine from BSL/Brammer. £66 sounds a it more than usual 🙁
Posted : 06/05/2009 2:34 pm
Does sound a lot. Local bearing supplier around £5 each though admittedly not skf.
Posted : 06/05/2009 2:38 pm
 gamo
sorry hijack! bumbly who is your local supplier? had a bit of a
hunt recently but ended up using betd, who i should say are not
cheap but sell enduro bearings which are good quality.
Posted : 06/05/2009 2:54 pm
try www.onlinebearings.co.uk if its not on there site give them a call 01282 693540
Posted : 06/05/2009 2:59 pm
[url= http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=4921894 ]RS Web NSK 6804[/url]
or, for an idea of price check on the RS web. They will be more expensive than BSL I'd have thought.
Posted : 06/05/2009 4:11 pm
IME, top end bearings don't last appreciably longer than the cheapos. Certainly not worth the money.
Posted : 06/05/2009 4:54 pm
