Bearing removal too...
[Closed] Bearing removal tool
Need to refurb and perhaps replace the bearings on my Evil Following
Can anyone recommend a decent and not too expensive bearing removal tool that covers a range of sizes
Don't want to risk doing a bodge job on a carbon frame. Was going to get the superstar ones but they seem to be discontinuing them and don't have many sizes left
Oli
Posted : 25/09/2016 12:30 pm
I've got this.
http://www.chainreactioncycles.com/rapidracerproducts-bearing-press-extraction-tool/rp-prod57883
Bloody expensive for what it is - essentially a length of threaded rod with a couple of machined nuts with integrated levers. Could've made my own for a fraction of the cost but then it'll last a lifetime.
You have to buy the bearing kits separately for around £20 each.
My biggest gripe is that given what it costs it could be supplied in a decent storage box that'll last. As it is, it's supplied in a flimsy cardboard box.
Posted : 25/09/2016 6:25 pm
I ordered one from ebay last week, just under £30 for 9 pullers and a slider bar. Also ordered a tool for fitting them. Wont be here for tomorrow and our EWS Finale trip so will keep our fingers crossed we dont need to change anymore on Abigales Enduro
Posted : 25/09/2016 6:40 pm
Yep, I recently bought the above rrp as the SS version going cheap was not in stock. Same comments as above.
Posted : 25/09/2016 6:44 pm
Have been looking myself.
Anybody know if this would do the job?
http://www.ebay.co.uk/itm/23Pc-Front-Wheel-Drive-Bearing-Removal-Installation-Tool-Kit-UK-/281893119968?_trksid=p2141725.m3641.l6368
Posted : 25/09/2016 6:58 pm
Proper ones to cover all sizes and cope with blind bearings will cost £100s.
Though I don't feel they should. The stuff is all knocked out of factories in china for likely £1 per tool and flogged in fancy branded kits to the west for £100s. But anyway.
The RRP, not sure how it works as an extractor, but DIY job is a few quid for a threaded rod, washers and wing nuts or similar. Extracting I have to use hammer and screwdriver (akin to using a drift).
Blind bearings are where you're stuck and may need proper tools, although I discovered my screw extractor set works great for smaller bearings as the biggest extractor can basically be screwed into the bearing race and then just pull out 😀
Posted : 25/09/2016 7:16 pm
It's a press with a receiver cup. I have a proper press and use a socket for the same thing. I have used threaded bar and washers previously, but frankly it was absolute shite. The thread tolerances are dreadful, and can skip.
I do not know why press makers (such as unior) don't supply a receiver kit or make a cup and collet type thing.
Posted : 25/09/2016 7:22 pm
Do you have the Ebay link for the one you bought please [b]Tracey[/b]
Posted : 25/09/2016 7:35 pm
Tracey, what was the bearing fitting press you ordered to go with it?
Posted : 25/09/2016 7:37 pm
Thanks [b]Tracey[/b]
Posted : 25/09/2016 7:53 pm
Tracey. I take it the blind puller extracts blind bearings. What tool do you then need to fit them again?
Posted : 25/09/2016 8:27 pm
Im hoping the universal bike bearing instalation tool kit will sort most of the Specialized bearings out.
Posted : 25/09/2016 8:31 pm
Well both the puller kit and the installation kit have arrived early. Got to say that they look the part, even if the puller kit is bigger and heavier than I expected. Proof will be when we come to use them. Will pack them in the camper tonight, that way I know we wont need them for our trip.
Posted : 26/09/2016 12:14 pm
Any updates on the kit?
Posted : 19/10/2016 4:10 pm
