Bearing removal and...
[Closed] Bearing removal and fitting...what do you use?.
What do you use for changing your bearings??
Is there any cheap ways of making a bearing press??
And what are the plastic things they use in bike shops to knock out the bearing with.....where can they be brought??
Cheers guys
Posted : 21/06/2015 9:07 pm
 Leku
I have a set of superstar tools. Makes changing the bearings on my Yeti (5) very easy.
http://www.superstarcomponents.com/en/bearing-removal-fitting-tool.htm
Posted : 21/06/2015 9:15 pm
Socket set and a vice normally.
Am waiting for a bearing press to turn up though. And bearing pullers seem to be a pain in the arse on frames as they flex slightly which stops the puller working.
Posted : 21/06/2015 9:17 pm
For knocking out, a screwdriver and mallet usually does the job. For inserting new ones, I used the fat end of a wooden hammer handle last week (and a mallet) cos it was just wide enough. I did make a headset press out of threaded bar and big washers some time ago but haven't got round to using it - rotating the bearing races cured the notching.
Posted : 21/06/2015 9:33 pm
A bearing press made from threaded bar, nuts and washers of various sizes, sockets, hammers, punches etc. Whatever gets the job done really. If the job is beyond my motley kit then it's off to the LBS.
Posted : 21/06/2015 9:41 pm
I bought the Superstar tools too.
Makes changing incredibly easy and quick.
Posted : 21/06/2015 9:56 pm
Hope tools for Hope stuff.Rapid Racer press for frame bearings. Occasional deadblow hammer and socket set extender bar when required. Santa Cruz Blur was a bespoke and v v efficient tool, was about 60 quid.
Posted : 21/06/2015 10:12 pm
Big hammers, old sockets and the freezer.
Changed the bearings in a brushcutter head, after that everything else is a bit easy.
Posted : 21/06/2015 10:19 pm
+1 for the Superstar tools, used them for the first time yesterday, really do make the job easy.
Posted : 21/06/2015 10:20 pm
Timber, try changing the bearings on a 15 year old round baler!
On a bike, an extensive socket set, various extensions and a very wide jawed vice will usually get most jobs done easily enough.
Posted : 21/06/2015 10:31 pm
I used a vice, it went horribly wrong lol
Posted : 21/06/2015 11:08 pm
Some great replies...didn't think about using a threaded bar, might give that ago
Posted : 22/06/2015 10:48 am
Anyone had any success with using the superstar tool on a hub? Looks like it may work with a longer bolt, and I have a back wheel that's a complete arse to get the new bearings in straight employing usual bodging methods.
Posted : 22/06/2015 10:55 am
Whatever's most appropriate, really. Most generally useful tool for removal is the rear axle from a 2010 Suzuki SV650, but I've got assorted screwdrivers and punches and such. And very occasionally, expanding bolts, for blind bearings.
Fitting, I'm a sockets man, but I vary between rubber mallets, the mighty hammer of Thor, vices, gclamps and threaded bar depending on the job.
Posted : 22/06/2015 10:58 am
Welshfarmer - witnessed the half way point of a baler bearing change at one of our tenant farms near Abergavenny after a few hard years use. Hard to say how successfully it was going.
Posted : 22/06/2015 10:44 pm
for hub bearings I have a spark plug socket tool that fits - also used a 12mm? masonary anchor bolt you can thread it through expand it and pull out the bearing [i]bodgtastic[/i]
Posted : 24/06/2015 5:00 am
No one using the Park tooks? Very expensive, but their bearing cup press looks a nice bit of kit.
Posted : 24/06/2015 8:26 am
If they're not blind, and the bearing is going to be binned, screwdriver and hammer or mallet to remove.
Fitting, if my headset press will fit I use that. Otherwise my DIY tool. Threaded rod, metal washers and wing nuts ๐Ÿ˜€ . Sometimes with a socket and old bearing sat on top of the new.
Branded tools tend to be one for a specific bearing size and to get all the tools for all the bearing sizes I have is stupidly expensive.
Posted : 24/06/2015 8:41 am
