anyone have the code to hand?
Thanks
Posted : 09/11/2009 11:56 am
endura bearing 2437
Posted : 09/11/2009 1:16 pm
61805 2RS from a bearing supplier.(some BBs have a slighly narrower bearing, 6mm not 7mm, apparently not available).
Posted : 09/11/2009 7:05 pm
As Coatesy say earlier models have a smaller width bearing so the shield won't fit the bearing code listed above. Though I suppose if you remove the inner lip once fitted they can't go anywhere. The endura bearing fit without out a shield that fits within the bearings, so have potential to damage the axle if the seize & you keep in riding ( axle can spin within the bearing causing wear).
Posted : 09/11/2009 7:30 pm
