BB Chainguide Insta...
[Closed] BB Chainguide Installation
Bought a top only guide recently however no instructions on how to fit. A quick internet search has indicated I need to remove a spacer from the drive side. However, should the guide be up tight against the frame or between a spacer and bb shell?
Posted : 28/09/2015 12:15 pm
If you've got two spacers on the drive side (68mm BB) then I'd remove the outer one (replace with guide) and leave the inner (against the frame).
The guide was presumably designed to work with both 68mm and 73mm BBs. A 73mm BB would only have one spacer.
Posted : 28/09/2015 12:24 pm
As above - but you may find yourself swapping around to get it to line up neater
Posted : 28/09/2015 12:30 pm
Thanks for your help, will go with ecky-thumps suggestion
Posted : 28/09/2015 2:44 pm
