Bash ring sizing qu...
[Closed] Bash ring sizing question.
When fitting a bash ring, do you choose a size equivalent to the big ring that you're removing (i.e. 42 / 44 tooth) or to match the size of the middle ring?
Cheers.
Posted : 26/04/2010 4:11 pm
Go for one that near enough matches the middle ring (though obviously it needs to be a bit bigger).
Posted : 26/04/2010 4:21 pm
Cheers, that seemed the obvious answer to me, but since there are big ones available (44t) it started to make me think that my assumption was wrong.
๐Ÿ˜•
Posted : 26/04/2010 4:24 pm
Sorry for the blatant plug, but if it helps?
http://www.singletrackworld.com/forum/topic/fs-saint-chainring-and-bashguard-1
Posted : 26/04/2010 4:25 pm
Solarider. I'm after a bash for a double ring setup. Your ad suggests it's designed for a single ring setup, or am I reading that wrong?
Posted : 26/04/2010 4:35 pm
I went for a double/bash ring set up. Initially had a 32t middle, so got the corresponding bash (ethirteen supercharger) which was fine. Then I changed for a 34t middle and the bash ring is still big enough, it actually doesnt clog up as much with mud now.
Posted : 26/04/2010 5:55 pm
same here 32t bash for 32t chainring
Posted : 26/04/2010 6:22 pm
Looks like the 32t and 34t bash are the same size 104mm or is that the PCD of the bolt holes?
Sod's law that all the 7 quid E13 superchargers on CRC are 5 hole! Just my luck!
Posted : 26/04/2010 6:43 pm
