Bash Ring question
[Closed] Bash Ring question
Is it ok to use a 36t bash ring with a 32t middle ring or will there be chain clearance issues?
Posted : 05/03/2009 9:23 pm
it'll be fine unless you're running an outer ring.
Posted : 05/03/2009 9:30 pm
Surely you'd have to run the bash as the outer ring? Can't run a 32t middle an outer and a bash!
Posted : 05/03/2009 9:32 pm
sharki - Member
Cheers, outter ring woudl obviously be replaced by the bash, it'd be interesting to see someone fit a 36t bash between a 32t middle and a 44t outer
timbur - Member
You're not kidding ๐Ÿ˜ฏ
Posted : 05/03/2009 9:35 pm
Cluckin bell, there is some rubbish spouted on here ๐Ÿ˜‰
Yup, you can run a 36t bash, no problems. Nothing to do with clearance issues, it just means it has a slightly larger diameter than a 32t bash. Same width as all the others. Just remember to adjust the H-stops on your front mech, shorten your chain and you'll be fine.
Posted : 05/03/2009 9:52 pm
