Bargain spotted on ...
[Closed] Bargain spotted on ebay - but have i ballsed up?
http://www.ebay.co.uk/itm/221355575509?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Just ordered a set of these as they seemed to be an absolute bargain but after ordering realised it says 10 speed and i need 9 speed. Can it be converted or will it be ok or am i selling them on!?
Posted : 17/02/2014 4:39 pm
 Sui
nothing to convert, it's up to you what cassette you put on. If it were 11, then it's a different kettle of fish.
Posted : 17/02/2014 4:43 pm
Yep, same freehub body, you'll be reet.
Posted : 17/02/2014 4:47 pm
As above, you'll be right. 9 and 10 speed fit on the same size free hub.
Posted : 17/02/2014 4:48 pm
Cheap!!
Posted : 17/02/2014 4:51 pm
brilliant, cheers. Now another question as i am a numpty. I have tubeless ready tyres, the stans fluid and a high pressure pump. What else do i need for the fitting?
Posted : 17/02/2014 4:53 pm
leythervegas - Member
A good vocabulary os swear words
Posted : 17/02/2014 5:17 pm
that is a bargain! although i need a QR rear. Can i convert the rear hub to QR anyone know?
Posted : 17/02/2014 5:40 pm
 nuke
21mm yellow tape and valves
Posted : 17/02/2014 5:57 pm
Superstars 25mm yellow tape and a pair of tubeless valves. Total cost £15
Posted : 17/02/2014 5:59 pm
 nuke
Could do that but get 21mm tape...they're the original Flow rims, not EX so internally are 22.6mm
Posted : 17/02/2014 6:05 pm
 tish
Does anyone know if these hubs are convertable?
I fancy trying these but my front is 15mm.
Posted : 17/02/2014 6:59 pm
That's not what stans recommend. I have 3 original flows all taped with 25mm. By the time you've gone in and out of the spoke bed the fit is spot on. I doubt 21mm tape would cover the small holes in the bead bench.
Posted : 17/02/2014 7:06 pm
Damn it they've gone up to £139.99 now 🙁
Posted : 18/02/2014 10:14 am
trickydisco - Member
Sun Ringle convertor & a normal QR will do it.
I've one knocking about but they're only £15 on CRC IIRC.
[url= http://www.chainreactioncycles.com/sun-ringle-rear-conversion-axle-2013/rp-prod65450 ]HERE[/url]
Posted : 18/02/2014 10:19 am
Anyone know who makes the Ibis hubs?
Posted : 18/02/2014 11:31 am
I think they are novatec
Posted : 18/02/2014 11:50 am
