Bar bung in bottom ...
[Closed] Bar bung in bottom of steerer. Will I die?
As above. Found an old bar bung in the bits box. Shoved it in steerer to keep crud out. Any reason not to?
Posted : 28/07/2014 3:37 pm
Nope
Posted : 28/07/2014 3:38 pm
Extremely dangerous thing to do!
After prolonged trail shredding you may find a pressure build up in the steerer assy causes the stem top cap to burst and thus blasting you whole damn face off!!!!
Note: only applies to 650b ers
Posted : 28/07/2014 3:45 pm
On a serious note, drill a small hole in the bung to let the water that does make it's way in, out.
Posted : 28/07/2014 3:49 pm
 DrP
It depends.
If the steerer is what you call a person in charge of a tandem, they might not like you much...
DrP
Posted : 28/07/2014 3:50 pm
Cheers. I'll drill a small hole in his bottom.
Posted : 28/07/2014 4:20 pm
