ok guys i am wanting to do a ride from threlkeld up the valley to skiddaw house and then around to mosedale and back through mungrisdale to threlkeld, has anyone done it and does anyone have a .gpx of it
cheers,
That's about as straightforward a route as there is in the Lakes, I'm pretty sure you won't need a GPX.
You really dont need a gpx for that mate, unless the clag is properly down.
Easy going on easy trails. Use BikeHike to make a gpx.
*beaten to it* ๐
Basically if you have an option then turn right.
Just keep Blencathra on your right & ride round it basically.
As said, no GPX required.
Cheers guys wasn't sure if there were any sections that weren't obvious, I will give it a blast in a couple of weeks
The only bit that might not be obvious is the BW leading down to the Caldew from Skiddaw House. Basically go through the gate and turn R immediately. Once you cross the river there's no other track
