I've managed to bend the cage on my 6 week old axs gx mech. (Snagged it on a thick bramble as I was following my four year old round on his bike)
Has anyone replaced the cage?
I've seen garbaruk ones which aren't cheap and not found a website with the standard cages in stock.
Any advice would be great as I really don't fancy replacing the whole mech.
Unfortunately it looks like only the inner cage is available as a spare part (and shared with NX / SX) - 11.7518.092.004
I guess you could take a punt on an NX / SX derailleur to scavenge for parts in the hope that the other half of the cage is compatible?
I fitted a Leonardi cage to drop a few grams on mine
Easy to do, two bolts.
Standard ones readily available also
https://r2-bike.com/SRAM-inner-cage-for-GX-Eagle-AXS-NX-Eagle-SX-Eagle-rear-derailleur
Anything that fits X01/XX1 won't work, threads are on the wrong side.
Or just go for it
https://r2-bike.com/KOGEL-BEARINGS-Oversized-Derailleur-Cage-System-Kolossos-SRAM-Eagle-mechanic-AXS
Thanks both of you, my issue seems to be that the outer cage isn't available (as frogstomp said).
I'm not really looking to spend £400 for the KOGEL set up to fix a £300 mech as nice as the bits are.
Garbaruk do a full cage but I don't think it fits the gx axs.
I put my gold XX1 cage on my GX AXS mech just to see what would happen... and it was gold.
I know that won't help your situation but, I do still have the GX AXS cage that I took off the brand new mech.
If you end up deciding to replace it anyway, I’d definitely try bending it back carefully first. Don’t know if a hanger straightening tool would help here, as never tried it! Combined with the micro-adjust on AXS might make it serviceable until the next disaster!!
I bought jaymcjayfaces's old cage which were much better condition than mine and I've got perfect shifts again. Thanks for the help everyone
