Avid Juicy Ultimate...
[Closed] Avid Juicy Ultimate Problems
Anyone know if ordinary Juicy pistons and seals will work in a Juicy Ultimate caliper? I'm having problems with pistons sticking in and when trying to fix it I've scratched a piston and made it worse. Seems that the Ultimate parts kit is hard to get hold of and also very expensive.
Posted : 19/04/2010 6:37 pm
I think they are exactly the same as normal Juicy's as it's basically what the actual caliper is made of that's the big difference and obviously the levers. Give CRC a call and ask them as they have loads of spares too. Mine don't appear any different to the Carbons and 7's I used to run.
Posted : 19/04/2010 6:43 pm
Sounds like you need to clean and lube the pistons rather than a calliper rebuild.
Posted : 19/04/2010 7:15 pm
 br
If not maintained the pistons will corrode and stick - I've a Juicy 7 caliper that I just cannot get the pistons out of (molegrips/compressors/the lot).
I got piston/seal kit for £11 from my LBS, but CRC also.
Posted : 19/04/2010 7:49 pm
Thanks for the replies all. I was hoping that the parts would be the same as the other juicys, but then I saw that there is an ulimate specific parts kit which put doubt in my mind. Think I might drop SRAM tech support a line.....
Posted : 19/04/2010 8:36 pm
The Carbons and Ultimate have got phelolic "bakerlite" pistons?
Oh - looks like the 7's and 5's also have them 🙂
http://www.chainreactioncycles.com/Models.aspx?ModelID=11972
Edit: I thought my juicy carbons had a metal peg in the piston?
Posted : 19/04/2010 8:43 pm
Only 8 quid at JE James (the ones I received didn't have the metal "pip" in the centre - it's the same material as the piston)
http://www.jejamescycles.co.uk/avid-juicy-pressure-foot-kit-id33896.html
I've bought some to do my Juicy Carbons which I buggered up when trying to free a sticky piston. Apparently a very thin smear of grease on the piston sides when installing them helps to prevent them sticking in the future. Not got round to replacing them yet though.
Posted : 19/04/2010 8:55 pm
 IA
Sticky pistons is a classic ultimate issue. No idea how to solve it tho other than a good service.
If you ever have to pop the pistons out to change seals, do yourself a favour and change the pistons too. They get brittle and chances are you'll knack them.
My juicy 3s have all plastic pistons. My ultimates and (older) fives have the metal pin.
Posted : 19/04/2010 8:58 pm
Is the consensus that 'ordinary' juicy pistons and seals should be ok?
Posted : 19/04/2010 9:48 pm
Did this get resolved, got problems with my Ultimates too, damaged piston.
Ta
Randy
Posted : 04/06/2010 12:25 pm
Yeah I ordered what I thought was Juicy 5 seals and got a Juicy ultimate kit. If all you want is the seals and pistons they're identical. There are different seals included though (e.g. the Reservoir cap seal).
Stu.
Posted : 04/06/2010 12:30 pm
So just to confirm this kit> http://www.chainreactioncycles.com/Models.aspx?ModelID=11972
will fit my ultimates?
Cheers for the quick reply
Randy
Posted : 04/06/2010 12:33 pm
